Do all apps transcode at the same speed, assuming other factors (codec, settings, source file) are the same?
I need to transcode about 40 files of 20-25 min each, because they won't play reliably on my Phillips DVP642. They're a mixture of Xvid 4 and Divx 5 (and all mp3) according to Gspot and Avicodec, so they should play fine in the 642, but they don't. The solution, I reckon, is to recopy them all using codecs and settings which are guaranteed to work in the 642. Thus, speed is a factor for this batch project. If app speed is pretty constant, assuming all other factors are constant, then I'll use the app that I like best. However, if some apps outpeform others in speed, even when source file, codec, settings, are the same, then I'll use what is fastest.
If you aren't resizing or doing any filtering then the only thing an app could really do to effect speed is to change colourspaces. Anything decent will keep the entire process in the same colourspace (YV12). Other than that, it is basically all down to the codec/setting being used. The impact of changing colourspaces will be compounded if you are filtering or resizing since you will have more information to process (say 24bit RGB vs 12bit YV12).
Is "colourspace" another way of describing the size of the color pallette (total number of possible colors)?
Not exactly. RGB and YUV are different ways of storing colour information.
http://en.wikipedia.org/wiki/YUV
Fact is that your source and output are YV12. So it is best to keep the entire process YV12. Doing otherwise will slow down encoding, which was the point I was trying to make. It also reduces quality.
How do I speed up my video to 10X speed?
By mileena in forum Newbie / General discussionsReplies: 9Last Post: 27th Aug 2010, 13:24 -
Which is better for speed and performance?
By SIRCOOKS in forum ComputerReplies: 3Last Post: 20th May 2010, 22:03 -
Burning speed vs. disc speed
By coody in forum DVD RippingReplies: 5Last Post: 26th May 2008, 02:41 -
The best codec/settings & application to run a 1080p flawlessly?
By r2builder in forum MacReplies: 8Last Post: 19th Apr 2008, 17:47 -
Speed increase?
By calbear94 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 13th Jul 2007, 08:45
