Hi,
I made DVD from mpeg with all titles, chapters etc.... But at that time i didn't know anything about safe (visible) zone for text (titles). And now when I play DVD on TV screen I can't see all titles.
I need software which alow you to resize that DVD (or mpeg) to see all titles.
Sorry about my english.
Thanx
titles - are you mean subtitels (translations)?
If so, you can reposition them up (if they are separate stream) with DVDSubEdit. -
It's not just a subtitles, its like text over whole screen and some other funy stuf which i made for DVD of my baby.
My guess is you are talking about painted/drawn on title's ... no , you can not cheat your way out of this , you will need to re-create them and regenerate the dvd .
For safe title area , checkout the back ground picture as supplied with dvdslideshowgui , it's handy to have and would have prevented this problem .
Dont worry ... I did this before ... someone wanted 36 clip's converted and dvd created ... I nearly went nutt's ... I mean I was dealing with the conversion of the full range of container's , avi , wmv , asf , mov , rm , mpeg1 ... resizing all to same size , ripping and converting audio , converting frame rate's to same value ... those that could not be upscaled where upscaled slightly and boxed inside black background ...
Then created the menu's ...
Firstly , some of the menu item's where not connected to there respective title's ... bugger me ... redo the rebiuld using pgcedit saved time .
Menu appeared fine on pc , and my tv , but for some reason it appeared stretched on their tv , even though they could be read ... missing some character's off screen ... I rebiult it once more after re-creating new menu background's , and it was finally perfect ...
It would have been cheaper to have shot myself ... last time I offer this to friend's , unless being paid well ... that was my first mistake .. doing it for free .
How to resize and convert MPEG-2 file so I can work with them in PrPro CS4?
By tomchook in forum Newbie / General discussionsReplies: 7Last Post: 13th Apr 2012, 12:02 -
ATI AIW 128 720x480 mpeg captures have horizontal tearing
By cybertheque in forum Capturing and VCRReplies: 16Last Post: 17th Sep 2008, 21:53 -
Crop/resize mpeg-2 to remove pop-up ad
By CaZeek in forum EditingReplies: 9Last Post: 8th Sep 2008, 23:43 -
Edit wedding video from vertical appearance to horizontal
By technofox01 in forum EditingReplies: 13Last Post: 19th Nov 2007, 13:47 -
Mobile video Horizontal - Vertical
By wayneyg in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2007, 12:07
