Hello I have a WINFAST TV2000 XP expert tv capture card which used to work fine in my pc. However lately when I try to capture using the mpeg2 video codec and the mpeg 1 audio layer 2 codec my audio seems to go out of synch the more of the movie is played. Other settings are 720x 576 PAL, variable bitrate, video compression mode = 666, Traget data Rate = 6000, Audio bitrate 224kbps.
I tried to also use the PICVIDEO MJPEG VfW codec and Mpeg layer 3 audio set at 48.000 khz and 256 kbs. However recording only lasts for a few seconds and then the image locks up.
This card used to work fine so I am not sure what the problem could be however and wondering if its also related to the fact that I am getting audio synch problems when trying to convert AVI files to vobs using either convertx to dvd pr tmpgenc.
Is it perhaps time I removed all of my codecs and started again? If so can someone suggest a list of good codecs to install?
Thanks in advance..
Not sure if this might help but here is a list of codecs I have installed.
Codec Reporting Utility Output Text
Date and Time: 23-May-2006 14:19:19
System Information
Operating System = Microsoft (R) Windows XP Professional (5.01.2600)
CPU Descriptor = Intel(R) Pentium(R) 4 CPU 2.40GHz
CPU Clock Speed = 2394 Mhz.
Total Memory = 1022 Mb.
DirectX Version = 9.0c
WMI Version = 2600.0000
ACM Version = 5.00.0
Video Codecs
AVI Decompressor
FileVersion = 6.05.2600.2749
CompanyName = Microsoft Corporation
FileDescription = DirectShow Runtime.
InternalName = Quartz.dll
LegalCopyright = Copyright (C) 1992-2001 Microsoft Corp.
OriginalFileName = Quartz.dll
ProductName =
ProductVersion = 6.05.2600.2749
AVI Draw
ProductName =
AVI_PASS
FileVersion = 2.00
CompanyName = Pinnacle Systems
FileDescription = AVI-MPEG Decapsulation Filter
InternalName = AVIPass.ax
LegalCopyright = Copyright (C) 2000 Pinnacle Systems.
OriginalFileName = AVIPass.ax
ProductName = AVIPass.ax
ProductVersion = 2.00
CineForm HD Codec V1.2
FileVersion = 1, 10, 7, 76
CompanyName = CineForm Inc.
FileDescription = CineForm VFW CODEC
InternalName = CFHD
LegalCopyright = Copyright © 2001-2005 CineForm Inc.
OriginalFileName = cfhd.dll
ProductName = Sony Vegas HDV
ProductVersion = 0, 0, 0, 24
Cirrus Logic USB-DVR2 Source
FileVersion = 5.4.6.3
CompanyName = Magnum Semiconductor
FileDescription = USB-DVR2 Source (DVC150)
InternalName = usbdvr2src
LegalCopyright = Copyright © 2005 Magnum Semiconductor
OriginalFileName = usbdvr2src.ax
ProductName = USB-DVR2
ProductVersion = 5.5.2
CyberLink Video/SP Decoder
FileVersion = 6.0.1921
CompanyName = CyberLink Corp.
FileDescription = CyberLink Video/SP Filter
InternalName = CLVSD.AX
LegalCopyright = Copyright (c) CyberLink Corp. 1997-2002
OriginalFileName = CLVSD.AX
ProductName = CyberLink PowerDVD
ProductVersion = 6.0.1921
DivX Decoder Filter
FileVersion = 6.1.1.1031
CompanyName = DivX, Inc.
FileDescription = DivX® Decoder Filter
InternalName = DivXdec.ax
LegalCopyright = Copyright © DivX, Inc., 2001-2006
OriginalFileName = DivXdec.ax
ProductName = DivX® Decoder Filter
ProductVersion = 6.1.1.1031
DivX Decoder Filter
DivX Subtitle Decoder
FileVersion = 0.0.0.026
CompanyName = DivXNetworks
FileDescription = DivX® Media Filter
InternalName = DivXMedia
LegalCopyright = Copyright © DivXNetworks, 2001-2005
OriginalFileName = DivXMedia.ax
ProductName = DivX® Media Filter
ProductVersion = 0.0.0.026
DivX® 6.1.1 Codec (2 Logical CPUs)
InternalName = DivX
LegalCopyright = Copyright © 2001-2006 DivX, Inc. All rights reserved.
OriginalFileName = DivX.dll
ProductName = DivX®
DivX® 6.1.1 YV12 Decoder
InternalName = DivX
ProductName = DivX®
DV Splitter
FileVersion = 6.05.2600.2180
InternalName = Qdv.dll
OriginalFileName = Qdv.dll
ProductName =
ProductVersion = 6.05.2600.2180
DV Video Decoder
ProductName =
DV Video Encoder
ProductName =
Huffyuv v2.1.1
FileVersion = 2.1.1
CompanyName = Disappearing Inc.
FileDescription = Huffyuv lossless video codec
InternalName = Huffyuv
LegalCopyright = Copyright © 2000 Ben Rudiak-Gould.
OriginalFileName = huffyuv.dll
ProductName = Huffyuv
ProductVersion = 2.1.1
Indeo® Video 4.5 Decompression Filter
FileVersion = 4.51.16.03
CompanyName = Ligos Corporation
FileDescription = Ligos Indeo® Video 4.5
InternalName = ir41_32.ax
LegalCopyright = © 1994-97 Intel Corp.; © 2000 Ligos Corp.
OriginalFileName = ir41_32.ax
ProductName = Ligos Indeo® Video 4.5
ProductVersion = 4.51.16.03
Indeo® video 5.10 Compression Filter
FileVersion = 5.11.15.2.56
FileDescription = Ligos Indeo® Video 5.11
InternalName = ir50_32.dll
LegalCopyright = © 1994-98 Intel Corp.; © 2000 Ligos Corp.
OriginalFileName = ir50_32.dll
ProductName = Ligos Indeo® Video 5.11
ProductVersion = 5.11.15.2.56
Indeo® Video 5.11 Compression Filter
Indeo® Video 5.11 Decompression Filter
Intel IYUV codec
FileVersion = 5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)
FileDescription = Intel Indeo(R) Video YUV Codec
InternalName = iyuv_32.dll
LegalCopyright = Copyright Intel Corporation 1992-1997
OriginalFileName = iyuv_32.dll
ProductName = Microsoft® Windows® Operating System
ProductVersion = 5.1.2600.2180
Ligos Indeo® Video 3.2
FileVersion = 3.24.15.04
FileDescription = Ligos Indeo® Video 3.2
InternalName = ir32_32.dll
LegalCopyright = © 1992-95 Intel Corp.; © 2000 Ligos Corp.
OriginalFileName = ir32_32.dll
ProductName = Ligos Indeo® Video 3.2 32-bit Driver
ProductVersion = 3.24.15.04
Ligos MPEG Splitter
FileVersion = 1.3.0.81
FileDescription = MPEG Parser Filter
InternalName = Mpeg2Parser.ax
LegalCopyright = Copyright © 2000 Ligos Corporation
OriginalFileName = Mpeg2Parser.ax
ProductName = LSX-MPEG Player
ProductVersion = 1.3.0.81
Ligos MPEG Video Decoder
FileVersion = 1.3.0.82
FileDescription = MPEG Decoder Filter
InternalName = Mpeg2Decoder.ax
OriginalFileName = Mpeg2Decoder.ax
ProductVersion = 1.3.0.82
MainConcept MPEG Video Decoder
FileVersion = 1, 0, 0, 66
CompanyName = MainConcept AG
FileDescription = MPEG Video and Audio Decoder
InternalName = MCDSMPEG.AX
LegalCopyright = Copyright (C) 2001-2004 MainConcept AG
OriginalFileName = MCDSMPEG.AX
ProductName = MPEG Decoder
ProductVersion = 1, 0, 0, 66
Microcrap MPEG-4 Video Decompressor
FileVersion = 8.00.00.4487
FileDescription = Microsoft MPEG-4 Video Decompressor
InternalName = mpg4ds32.ax
LegalCopyright = Copyright (C) Microsoft Corp. 1996 - 2001
OriginalFileName = mpg4ds32.ax
ProductName = Microsoft MPEG-4 Video Decompressor
ProductVersion = 8.00.00.4487
Microsoft H.263 Video Codec
FileDescription = Microsoft H.263 ICM Driver
InternalName = msh263
LegalCopyright = Copyright © Intel Corp. and Microsoft Corporation 1995-1999
OriginalFileName = msh263.drv
ProductName = Windows® NetMeeting®
ProductVersion = 3.01
Microsoft MPEG-4 Video Codec V1
FileVersion = 4.1.00.3920
FileDescription = Microsoft MPEG-4 Video Codec
InternalName = mpg4c32
LegalCopyright = Copyright (C) Microsoft Corp. 1996-1999
OriginalFileName = mpg4c32
ProductName = Microsoft MPEG-4 Video Codec
ProductVersion = 4.1.00.3920
Microsoft MPEG-4 Video Codec V2
Microsoft MPEG-4 Video Codec V3
FileVersion = 8.0.0.0344
LegalCopyright = Copyright (C) Microsoft Corp. 1996-2001
ProductVersion = 8.0.0.0344
Microsoft RLE
FileDescription = Microsoft RLE Compressor
InternalName = msrle32.dll
LegalCopyright = © Microsoft Corporation. All rights reserved.
OriginalFileName = msrle32.dll
Microsoft Screen Video Decompressor
FileDescription = Microsoft Screen Video Decompressor
InternalName = mss1.ax
LegalCopyright = Copyright (C) Microsoft Corp. 1999 - 2001
OriginalFileName = mss1.ax
ProductName = Microsoft Screen Video Decompressor
Microsoft Video 1
FileVersion = 5.1.2600.0 (xpclient.010817-1148)
FileDescription = Microsoft Video 1 Compressor
InternalName = msvidc32.dll
OriginalFileName = msvidc32.dll
ProductVersion = 5.1.2600.0
MJPEG Compressor
ProductName =
MJPEG Decompressor
ProductName =
MPEG Video Decoder
ProductName =
Mpeg4 Decoder DMO
FileVersion = 9.00.00.3250
FileDescription = Corona Windows Media MPEG-4 Video Decoder
InternalName = mpg4dmod.dll
OriginalFileName = mpg4dmod.dll
ProductName = Microsoft® Windows Media Services
ProductVersion = 9.00.00.3250
Mpeg43 Decoder DMO
FileDescription = Windows Media MPEG-4 Video Decoder
Mpeg4s Decoder DMO
FileDescription = Corona Windows Media MPEG-4 S Video Decoder
InternalName = mp4sdmod.dll
OriginalFileName = mp4sdmod.dll
MSScreen 9 encoder DMO
FileVersion = 10.00.00.3802
FileDescription = Corona Windows Media Screen Encoder
InternalName = wmsdmoe.dll
OriginalFileName = wmsdmoe.dll
ProductVersion = 10.00.00.3802
Nero Digital AVC Video Enc
FileVersion = 3, 2, 0, 7
CompanyName = Nero AG
FileDescription = MPEG4 and H.264 (AVC) video encoder
InternalName = NeroDigitalVideoEnc.ax
LegalCopyright = Copyright (c) 1995-2005 Nero AG and its licensors
OriginalFileName = NeroDigitalVideoEnc.ax
ProductName = NeroDigital
ProductVersion = 2, 6, 4, 60
Panasonic DV CODEC
FileVersion = 2, 64, 1119, 1600
CompanyName = Matsushita Electric Industrial Co., Ltd.
FileDescription = DV Video for Windows Driver
InternalName = DV Video for Windows Driver
LegalCopyright = Copyright (C) Matsushita Electric 1998
OriginalFileName = pdvcodec.dll
ProductName = Panasonic DV CODEC
ProductVersion = 2, 64, 1119, 1600
PICVideo M-JPEG 3 DirectShow Compressor
FileVersion = 3.0.0.12
CompanyName = Pegasus Imaging Corporation
FileDescription = PICVideo M-JPEG 3 codec
InternalName = pvmjpg30
LegalCopyright = Copyright © 1997-2005 Pegasus Imaging Corporation. All rights reserved.
OriginalFileName = pvmjpg30.dll
ProductName = PICVideo Codec Suite
ProductVersion = 3.0.0.0
PICVideo M-JPEG 3 DirectShow Decompressor
PICVideo M-JPEG 3 VfW Codec
Pinnacle DCxx MJPEG Decompressor
FileVersion = 3.1.0.3
CompanyName = Pinnacle Systems, Inc.
FileDescription = Pinnacle MJPEG decompress filter
InternalName = MJPEG decompress filter
LegalCopyright = MJPEG core: Copyright © 1998-2000, Avery Lee; Filter shell: Copyright © 1998-2003, Pinnacle Systems, Inc.
OriginalFileName = MJPGDecompress.ax
ProductName = MJPEG decompress filter
ProductVersion = 1.0.0.0
Pinnacle MPEG 2 Encoder
FileVersion = 5.0.246.00
CompanyName = Pinnacle Systems GmbH
FileDescription = Pinnacle MPEG Codec - DirectX Filter
InternalName = PCLEMPEG
LegalCopyright = © 2003-2006 by Pinnacle Systems GmbH
OriginalFileName = PCLEMPEGBox.ax
ProductName = Pinnacle MPEG Codec
ProductVersion = 5.0.246.00
QT Decompressor
ProductName =
VBI Surface Allocator
FileVersion = 5.3.2600.2180 (xpsp_sp2_rtm.040803-2158)
FileDescription = VBI Surface Allocator Filter
InternalName = VBISURF.AX
OriginalFileName = VBISURF.AX
ProductName = Microsoft(R) Windows(R) Operating System
ProductVersion = 5.3.2600.2180
Video Port Manager
ProductName =
Windows Media Video Decoder
FileDescription = Windows Media Video Decoder
InternalName = wmvds32.ax
OriginalFileName = wmvds32.ax
ProductName = Windows Media Video Decoder
FileVersion = 8.0.0.4000
FileDescription = Windows Media Video Decoder V8
InternalName = wmv8ds32.ax
OriginalFileName = wmv8ds32.ax
ProductName = Windows Media Video Decoder V8
ProductVersion = 8.0.0.4000
WinFast TV2000 XP Expert WDM Video Capture.
FileDescription = WDM Streaming ActiveMovie Proxy
InternalName = ksproxy.ax
OriginalFileName = ksproxy.ax
WMV Screen decoder DMO
FileDescription = Windows Media Screen Decoder
InternalName = wmsdmod.dll
OriginalFileName = wmsdmod.dll
WMVideo Advanced Decoder DMO
FileDescription = Windows Media Video 9 Decoder
InternalName = wmv9dmod.dll
OriginalFileName = wmv9dmod.dll
WMVideo Advanced Encoder DMO
WMVideo Decoder DMO
InternalName = wmvdmod.dll
OriginalFileName = wmvdmod.dll
WMVideo9 Encoder DMO
FileDescription = Windows Media Video Encoder
InternalName = wmvdmoe2.dll
OriginalFileName = wmvdmoe2.dll
Audio Codecs
AC3 from AVI XForm
FileVersion = 2.20.00
CompanyName = Kristal Studi
FileDescription = AC3AUDI
InternalName = decaudio.a
LegalCopyright = Copyright (C) 2000-2001, Kristal Studio
OriginalFileName = decaudio.a
ProductName = Audio Decode
ProductVersion = 2.20.00
AC3 Prologic Decoder
InternalName = ac3Audio.a
OriginalFileName = ac3Audio.a
ProductName = AC3 Audio Decode
AC3Filter
FileVersion = 1.01a
CompanyName =
FileDescription = ac3filter
InternalName = ac3filter
LegalCopyright = Copyright © 2002-2004 by Alexander Vigovsky
OriginalFileName = ac3filter.ax
ProductName = AC3Filter
ProductVersion = 1.01a
ACELP.net
FileVersion = 3.02
CompanyName = Sipro Lab Telecom Inc.
FileDescription = Audio codec for MS ACM
InternalName = sl_anet.acm
LegalCopyright = Copyright © Sipro Lab Telecom Inc. 1998-99
OriginalFileName = sl_anet.acm
ProductName = ACELP.net Audio Codec
ProductVersion = 3.02
ACELP.net Sipro Lab Audio Decoder
FileVersion = 1.40
FileDescription = ACELP.net Audio Decoder
InternalName = AcelpDec.ax
LegalCopyright = Copyright (C) 1997-99 Sipro Lab Telecom Inc.
OriginalFileName = AcelpDec.ax
ProductName = ACELP.net Audio Decoder
ProductVersion = 1.40
ACM Wrapper
ProductName =
CCITT A-Law
FileDescription = Microsoft CCITT G.711 (A-Law and u-Law) CODEC for MSACM
InternalName = Microsoft CCITT G.711 (A-Law and u-Law) CODEC for MSACM
OriginalFileName = msg711.acm
CCITT u-Law
CyberLink Audio Decoder
FileVersion = 6.00.2001
FileDescription = CyberLink Audio Decoder Filter
InternalName = CLAUD.AX
LegalCopyright = Copyright (c) CyberLink Corp. 1997-2004
OriginalFileName = CLAud.ax
ProductName = CyberLink Audio Decoder Filter
ProductVersion = 6.00.2001
DSP Group TrueSpeech(TM)
FileVersion = 1.01
CompanyName = DSP GROUP, INC.
FileDescription = DSP Group TrueSpeech(TM) Audio Codec for MSACM V3.50
InternalName = tssoft32.acm
LegalCopyright = Copyright DSP Group, Inc. 1993-1996
OriginalFileName = tssoft32.acm
ProductName = DSP GROUP Windows NT(TM) TrueSpeech CODEC
GSM 6.10
FileDescription = Microsoft GSM 6.10 Audio CODEC for MSACM
InternalName = Microsoft GSM 6.10 Audio CODEC for MSACM
OriginalFileName = msgsm32.acm
IAC2
FileVersion = 2.05.54
FileDescription = Indeo® Audio Software
InternalName = iac25_32.ax
LegalCopyright = © 1997 Intel Corp.; © 2000 Ligos Corp.
OriginalFileName = iac25_32.ax
ProductName = Indeo® Audio Software
ProductVersion = 2.05.54
IMA ADPCM
FileDescription = IMA ADPCM CODEC for MSACM
InternalName = IMA ADPCM CODEC for MSACM
OriginalFileName = imaadp32.acm
Leadtek Audio Decoder
FileVersion = 3.5.0301
CompanyName = Leadtek Research Inc.
FileDescription = Leadtek Audio Filter
LegalCopyright = The Leadtek filter developed by CyberLink Corp. All rights reserved.
OriginalFileName = CLAUD.AX
ProductName = WinFast TV
ProductVersion = 3.5.0301
MainConcept MPEG Audio Decoder
Microsoft ADPCM
FileDescription = Microsoft ADPCM CODEC for MSACM
InternalName = Microsoft ADPCM CODEC for MSACM
OriginalFileName = msadp32.acm
Microsoft G.723.1
FileVersion = 4.4.3400
FileDescription = Microsoft G.723.1 CODEC for MSACM
InternalName = msg723
OriginalFileName = msg723.acm
Morgan Stream Switcher
FileVersion = 0.94ß
CompanyName = Morgan Multimedia
FileDescription = MM Switcher
InternalName = MMSwitch.ax
LegalCopyright = Copyright (C) 1990-2001 Morgan Multimedia.
OriginalFileName = MMSwitch.ax
ProductName = Morgan Multimedia Stream Switcher
ProductVersion = 0.94ß
MPEG Audio Decoder
ProductName =
MPEG Layer-3
FileVersion = 3, 3, 2, 44
CompanyName = Fraunhofer Institut Integrierte Schaltungen IIS
FileDescription = MPEG Audio Layer-3 Codec for MSACM
InternalName = l3codec.acm
LegalCopyright = Copyright © 2004 Fraunhofer IIS
OriginalFileName = l3codec.acm
ProductName = Fraunhofer IIS MPEG Audio Layer-3 ACM codec
ProductVersion = 3, 3, 2, 44
MPEG Layer-3 Decoder
FileVersion = 1, 5, 0, 50
FileDescription = MPEG Layer-3 Audio Decoder
InternalName = L3CODECX.AX
LegalCopyright = Copyright (C) 1997 Fraunhofer IIS
OriginalFileName = L3CODECX.AX
ProductName = MPEG Layer-3 Audio Codec for Microsoft DirectShow
ProductVersion = 1, 5, 0, 50
Nero Audio Encoder
FileVersion = 1, 0, 0, 4
CompanyName = Ahead Software AG
Karlsbad
Germany
Phone: ++49-7248-911-800
Fax: ++49-7248-911-888
E-Mail: info@nero.com
FileDescription =
InternalName =
LegalCopyright = Copyright © 1995-2003 Ahead Software AG
OriginalFileName =
ProductName =
ProductVersion = 1, 0, 0, 1
Nero Digital Audio Decoder
CompanyName = Nero AG and its licensors
FileDescription = Nero Digital Audio Decoding Filter
InternalName =
LegalCopyright = Copyright (C) 2005 Nero AG and its licensors
OriginalFileName = NeAudio.ax
ProductName =
ProductVersion = 1, 0, 4, 49
Ogg Vorbis (mode1)
FileVersion = 0, 0, 3, 0
CompanyName = HMS http://hp.vector.co.jp/authors/VA012897/
FileDescription = Ogg Vorbis CODEC for MSACM
InternalName = vorbis
LegalCopyright = Copyright (C)2001 H.Mutsuki
OriginalFileName = vorbis.acm
ProductName = Ogg Vorbis Audio codec for MSACM
ProductVersion = 0, 0, 3, 0
Ogg Vorbis (mode1+)
Ogg Vorbis (mode2)
Ogg Vorbis (mode2+)
Ogg Vorbis (mode3)
Ogg Vorbis (mode3+)
PCM
Pinnacle AC3 Decoder
FileVersion = 1.0.94.00
FileDescription = Pinnacle AC3 Decoder - AC3 Decoder Filter
InternalName = Pinnacle AC3 Decoder
LegalCopyright = © 2004-2005 by Pinnacle Systems GmbH
OriginalFileName = PcleAC3Decoder.ax
ProductName = Pinnacle AC3 Decoder
ProductVersion = 1.0.94.00
Pinnacle AC3 Encoder (2 Channels)
FileVersion = 1.0.6.00
FileDescription = AC3 Consumer Encoder - 2 Channels only
InternalName = AC3 Consumer Encoder
OriginalFileName = PcleAC3Enc2Ch.ax
ProductName = AC3 Consumer Encoder
ProductVersion = 1.0.6.00
Pinnacle AC3 Encoder (5.1 Channels)
FileDescription = AC3 Consumer Encoder - 5.1 Channels
OriginalFileName = PcleAC3Enc5_1Ch.ax
Pinnacle Audio Codec
FileVersion = 1.0.86.00
FileDescription = PcleAudioCodec - AudioCodec
InternalName = PcleAudioCodec
OriginalFileName = PcleAudioCodec.ax
ProductName = PcleAudioCodec
ProductVersion = 1.0.86.00
Pinnacle MP3 Encoder
FileVersion = 9.3.0.5
FileDescription = Pinnacle MP3 compressor
InternalName = PcleMP3Encoder.ax
OriginalFileName = PcleMP3Encoder.ax
ProductName = Generic
ProductVersion = 9.3.0.5
Pinnacle MPEG Layer-2 Audio Encoder
Pinnacle(dicas) AMR Audio Decoder
FileVersion = 2.3.86.0
CompanyName = dicas digital image coding GmbH
FileDescription = dsamrauddec
InternalName = dsamrauddec
LegalCopyright = Copyright © 2003-2004 dicas GmbH
OriginalFileName = dsamrauddec.ax
ProductName = DirectShow(C) AMR Audio Decoder
ProductVersion = 2.3.86.0
SB Live! Wave Device
InternalName = QCap.dll
OriginalFileName = QCap.dll
ProductName =
Vorbis Decoder
FileVersion = 0, 9, 9, 5
CompanyName =
FileDescription = Ogg DirectShow(tm) Filter Collection
InternalName = OggDS
LegalCopyright = Copyright (C) 2002 Tobias Waldvogel
OriginalFileName = OggDS.DLL
ProductName = Ogg DirectShow(tm) Filter Collection
ProductVersion = 0, 9, 9, 5
Vorbis Encoder
CompanyName =
Windows Media Audio Decoder
FileDescription = Windows Media Audio Decoder
InternalName = msadds32.ax
LegalCopyright = Copyright (C) Microsoft Corp. 1999-2001
OriginalFileName = msadds32.ax
ProductName = Windows Media Audio Decoder
Windows Media Audio V1
FileVersion = 4.2.00.000
FileDescription = DivX WMA Audi
InternalName = DivXa3
LegalCopyright = Copyright (C) 1999-2000 Kristal Studi
OriginalFileName = DivXa3
ProductName = DivX WMA Audi
ProductVersion = 4.2.00.000
Windows Media Audio V2
WM Speech Encoder DMO
FileDescription = Windows Media Audio 9 Voice Encoder
InternalName = wmspdmoe.dll
OriginalFileName = wmspdmoe.dll
WMAPro over S/PDIF DMO
InternalName = wmadmod.dll
OriginalFileName = wmadmod.dll
WMAudio Decoder DMO
WMAudio Encoder DMO
FileDescription = Windows Media Audio Encoder/Transcoder
InternalName = wmadmoe2.dll
OriginalFileName = wmadmoe2.dll
WMSpeech Decoder DMO
FileDescription = Windows Media Audio 9 Voice Decoder
InternalName = wmspdmod.dll
OriginalFileName = wmspdmod.dll
Broken Codecs
Bicubic Video Resizer
FileName =
Nero Digital Video Encoder
FileName =
NVVPE
FileName =
Pinnacle DCxx MJPEG Compressor
FileName =
Subtitle Mixer
FileName =
XLCompress
FileName =
XLDecompress
FileName =
XLDecompress
FileName =
Audio synch problems
By davehaze in forum Newbie / General discussionsReplies: 0Last Post: 18th Jul 2011, 08:27 -
Audio/video synch problems ... again ...
By Diana (Cda) in forum Newbie / General discussionsReplies: 1Last Post: 6th Jul 2011, 22:59 -
Audio synch problems after muxing.
By avengerevenge in forum Newbie / General discussionsReplies: 4Last Post: 21st Jan 2011, 20:27 -
WinAVI 9.0 Audio synch problems
By Marshfish in forum Newbie / General discussionsReplies: 5Last Post: 21st May 2008, 13:10 -
By zinc in forum AudioReplies: 4Last Post: 6th Jul 2007, 23:22
