Hello, i am new here. When i try to burn a dl dvd with Nero 7 ultra edition i get a message that comes up that says "Dvd- video files reallocation failed. The resulting dvd might be unplayable. Do you want to continue?" Any info would be appreciated. I hope i phrased it right.
Fairly common with Nero. You might be able to get away with burning even with the error, but I would use a different burring program, such as RecordNow or Prassi Ones. Or if you are using DVDShrink for the source, DVD Decrypter. Decrypter is also the easiest for direct backups to DL: ISO Read > ISO Write.
Here's some info for the Nero error and a possible cure from the Digital-Digest forum: http://forum.digital-digest.com/showpost.php?p=238907&postcount=14
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 16Last Post: 16th Dec 2019, 23:18 -
burning disc's but nothing shows on the disc
By qman7112 in forum Newbie / General discussionsReplies: 1Last Post: 16th Nov 2010, 14:51 -
I was burning a dvd and got this message!!
By hollywoodfussell in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2007, 00:49 -
NERO gives me error message when burning DVD
By qwazi in forum Authoring (DVD)Replies: 8Last Post: 10th Aug 2007, 02:01 -
Panasonic DMR-HS2 gives me a U11 message when I try to put any disc in...
By garylime in forum DVD & Blu-ray RecordersReplies: 1Last Post: 3rd Aug 2007, 15:40
