My First Post so pls be gentle.
As great as the multitude of endless compression schemes are they are difficult to edit.
There must be an Application that will Demux a Mpeg1 + Mpeg2 + Divx Xvid & there variants Interlaced or Progressive streams to something thats Simple & Framed based that Adobe Premiere Pro can use - Perhaps like DV or EVEN RAW (yes Im that desperate)
when I import several different type clips onto the timeline Some will encode OK while others are choppy/break up or basically a mess.
Thankyou Thankyou Thankyou
Its never easy keeping it simple....
i think you mean re-encode , not demux ...
big diff...
big time to do so .....
why not use a NLE that accepts most or all these formats in the first place ?"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Your right on both counts. However premiere is my preferred choice.
Since my post I have tried Virtualdub again & it seems a lot friendlier than I remembered. It seems to work nicely - So I give it a try & see how that goesIts never easy keeping it simple....
Demuxing WMV using Windows Media Stream Editor
By Bully9 in forum EditingReplies: 11Last Post: 19th Mar 2013, 17:43 -
stream xvid to xbox360
By sdvideohelp in forum Video Streaming DownloadingReplies: 11Last Post: 10th Feb 2012, 09:32 -
Can't Stream An XVID file to PS3
By CrazedSyko in forum Video Streaming DownloadingReplies: 3Last Post: 19th Jul 2008, 11:48 -
Problems with Xvid audio stream
By mijman in forum Authoring (DVD)Replies: 3Last Post: 15th Apr 2008, 23:59 -
Xvid stream to PS3
By Sooner02 in forum Media Center PC / MediaCentersReplies: 5Last Post: 2nd Jan 2008, 13:44
