  1. tried DivFix, it crashes halfway through after telling me there is a corrupt frame.
    tried VirtualDub, crashes when i try to open the file -- regardless of the options i select.
    tried Premiere... can't open the file.
    When i open a window containing the broken file, CPU usage for explorer.exe goes to 100% and stays there as windows unsuccessfully tries to find the resolution, duration, etc. of the file.
    Any ideas ?
  2. Hi,
    Have you tried TMPGEnc?
    You maybe able to encode to .MPG upto the damaged frame, then encode from the damaged frame +1 frame then join the 2 .MPG's again using TMPGEnc.
    I have had to do this many times and if only 1 or a couple frames are damaged, you want notice much disturbance.
    Cheers.
    ©.¸¸.·´¯`·.¸¸.·´¯`·.¸¸.·´¯`·-- KennyC --·´¯`·.¸¸.·´¯`·.¸¸.·´¯`·.¸¸.©
    <font size=-1>[ This Message was edited by: KennyC on 2002-01-05 17:11:44 ]</font>
