I have a bunch of avi files that I want to store on a DVD. I want to put as much as I can on each DVD. AVI's are much smaller files than MPEG-2's. Do I have to convert the files to MPEG-2 or can I just burn the AVI's onto the disc? Would using a DVD-RAM disc work?
If you just want to store them for later use on your pc you can just burn them as data no problem. IF you want to WATCH them on your dvd player it has to say its DIVX COMPATIBLE. Otherwise you have to convert them to mpeg2 and author the dvd so the normal dvd player will read them.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
For storage you can just burn them as-is, thereby creating a data DVD (as opposed to a DVD-video).Originally Posted by jtltoy"Art is making something out of nothing and selling it." - Frank Zappa
I have Nero 6, but don't see choices of making just a data disc. Is there another program I should use?
Google turned up this: http://www.nero.com/nero6/en/Tutorial_Data.htmlOriginally Posted by jtltoy"Art is making something out of nothing and selling it." - Frank Zappa
Thanks, I never used StartSmart, so I didn't even know it was there. This will make things much easier.
Saving/capture solutions for saving off (extending) DVR
By ET3D in forum Newbie / General discussionsReplies: 1Last Post: 28th Oct 2011, 19:13 -
Deinterlacing MiniDV AVI file and saving as lossless AVI
By Dave2ic in forum Video ConversionReplies: 3Last Post: 27th Dec 2010, 16:11 -
VirtualDub: Saving Segmented Avi
By Ruro Jiruries in forum EditingReplies: 0Last Post: 18th Jun 2009, 08:13 -
saving avi to different tv sze
By thecrock in forum Newbie / General discussionsReplies: 5Last Post: 14th Dec 2008, 14:26 -
saving files with all to avi
By pw29010 in forum Video ConversionReplies: 6Last Post: 26th Sep 2007, 15:50
