Ok im using this guide
https://forum.videohelp.com/viewtopic.php?t=225951
and this is the script i saved
LoadPlugin("C:\pgfilters\Convolution3d.dll")
avisource("C:\jskko.avi")
SeparateFields()
odd=SelectOdd.Convolution3D (0, 32, 128, 16, 64, 10, 0)
evn=SelectEven.Convolution3D (0, 32, 128, 16, 64, 10, 0)
Interleave(evn,odd)
Weave()
DoubleWeave.SelectOdd()
ConvertToYUY2(interlaced=true)
i switched the converttoRGB and to what it is now and when i try to open it in windows media player i get the error about extensions then this show on screen
convolution supports yuy2 color format only
c:\sokkotest.avs, line 4
what am i doing wrong
help
The error message is telling you that you need to ConvertToYUY2 before you call Convolution3D. Move the ConvertToYUY2 line to just before the SeparateFields() line.
You may need to put the ConvertToRGB back at the end depending on what encoder you are feeding to."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
Ok thanks gadgetguy i got it to work im up to the part in the instructions where i did the Import frameset as trims from that screan do i just hit save and open in cce and encode? Is is the encoding part of the cce (when i open that avs file in cce) where the filters are applied
In other words where does the cleaning solution get applied lol -
Hi-
After you have the script the way you think you want it, save it, and then test it out by opening it in VDub(Mod) or WMP to check if there's an error message and to scroll around to make sure everything's OK.
If it's OK, drag it into the CCE window and right-click on it to access the CCE settings.
For CCE you only want ConvertToYUY2(interlaced=true), and nothing about RGB. And yes, the filters you applied in your script will get encoded that way in CCE.
Avisynth filter RemoveDirt not doing anything
By ThePhoenix in forum Newbie / General discussionsReplies: 10Last Post: 4th Mar 2012, 18:40 -
AviSynth and Filter Order
By sambat in forum EditingReplies: 3Last Post: 11th Jan 2012, 10:04 -
Lav filter and avisynth
By Creed in forum Newbie / General discussionsReplies: 7Last Post: 15th Dec 2011, 16:10 -
Need Avisynth filter
By fubuki81 in forum RestorationReplies: 5Last Post: 30th Sep 2008, 13:04 -
Logoaway filter for AviSynth?
By DRP in forum Video ConversionReplies: 2Last Post: 8th Aug 2008, 04:30
