Hello everyone,
I have all the episodes of Star Trek TNG downloaded and they are currently in Divx format. What I was hoping to do was to burn them onto a dvd- so that I can watch them on my tv with my dvd player. Can someone explain to me or link to me the process I would have to do this so that I can select each episode on the dvd, etc.
Thanks for your help.
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator mats.hogberg
Closed Thread
Hello Cybrex,
If you're not fussed about menus (I.E. you just want the video on the DVD so that it will play on your DVD player) then you could try WinAVI.
HTH
No, not WinAVI... Anything but that piece of monkey****! (No, really, I'm serious, WinAVI is considered training wheels and worse around here.)
You might want to try ConvertXtoDVD2 (used to be known as DivxtoDVD).
(Check it in the TOOLS selection on the left pane.)
Another idea, you may wish to consider changing out your DVD player to one that also plays DIVX files. I have the Phillips 642 and LG LDA-511. This way, the DVDs you make can be either/or.Whatever doesn't kill me, merely ticks me off. (Never again a Sony consumer.)
You could also thank yourself in later years by buying series 1-7 on DVD here:
http://www.amazon.com/gp/product/B00062RCBW/qid=1148384000/sr=8-1/ref=pd_bbs_1/002-337...v=glance&n=130If in doubt, Google it.
No help with wares at this site. Buy the DVD.
/Mats
Convert divx to dvd
By willcuk22 in forum Video ConversionReplies: 5Last Post: 14th Feb 2010, 03:46 -
Do i need to convert if i have a divx dvd player?
By extreme1000 in forum Video ConversionReplies: 7Last Post: 3rd Jul 2008, 07:42 -
What is the fastest way to convert XVID/DIVX TO DVD
By goheadtry in forum Newbie / General discussionsReplies: 8Last Post: 23rd Nov 2007, 08:33 -
how to convert divx to dvd
By redwolf28386 in forum Video ConversionReplies: 22Last Post: 25th Aug 2007, 07:33 -
I need to convert dvd into avi!not xvid or divx!
By picky2112 in forum DVD RippingReplies: 5Last Post: 6th Jul 2007, 02:22
