when i convert my avi files to Mpeg1, i just select the Videocd(ntsc) template, but what the best settings( all round in terms of size of quality of the Mpeg File) that i can configure myself ?
Well... the templates are fine... You can unlock the templates using the Unlock template (!). Then you can change the setting for youself you think you can do it better. You can of course change the CBR to VBR and then the qualtiy is a lto betterbut since that is not the VCD standard, it's not for sure to work in a DVD player. My Samsung 611 only accept CBR coded VCD.
Thanx/
Lars
Settings TMPGEnc to FFMpeg
By Nologic in forum Video ConversionReplies: 0Last Post: 5th Apr 2012, 23:15 -
TMPGEnc Settings?
By chronic777 in forum Video ConversionReplies: 3Last Post: 27th Jul 2009, 10:14 -
Help with TMPGEnc 4.0 XPress Settings
By mister_to_you in forum Video ConversionReplies: 0Last Post: 20th Jun 2008, 10:01 -
TMPGEnc DVD settings
By Bully9 in forum Authoring (DVD)Replies: 3Last Post: 12th Mar 2008, 09:22 -
Doubt about TMPGEnc Plus' settings
By alvabass in forum Video ConversionReplies: 1Last Post: 13th Jun 2007, 12:52
