Hi :
I'm joining two avi's file which are in Xvid format and when I want to join them I use xvid format but after the process is complete I have no sound ? what is the problem and how I can solve it ?
what is the audio format?
what tool do you use?
try virtualdubmod -
Hi
from your post it sounds like you are rencoding your avi,try following the guide for joining avi here. http://www.dvd-guides.com/guides.php?category=avi&name=avijoin -
I'm using mpeg layer 3 for audio and I use join split conver video 1.
and all video join
audio sync problem joining two avi files
By kthan in forum EditingReplies: 11Last Post: 2nd Apr 2011, 13:52 -
Problem joining (concatenating) avi's in virtualdub
By uart in forum EditingReplies: 6Last Post: 21st Nov 2008, 16:44 -
Joining avi's - problem with differing bitrates
By Topher5000 in forum EditingReplies: 6Last Post: 12th Aug 2007, 21:54 -
Audio Sync Problem Joining 2 AVI's Together from a 2 DVD Set
By boofer in forum EditingReplies: 6Last Post: 22nd Jul 2007, 02:29 -
Problem Joining AVI files with MEncoder
By RetSpec in forum EditingReplies: 1Last Post: 6th May 2007, 23:00
