Hi all:
This may sound a stupid question but I have no problems in trancoding my AVI files into DVD and even adding subtitles .
However I am having problems when I got a movie on MPG format !!!.
Whats the best way to create a DVD (also adding subs) from a MPG file ??
I've been transcoding the MPG file into AVI with media coder, and I managed to coordinate the Subs with subtitle workshop, the only problem is that on the final movie the video is not synchronized with the audio (we can see actores speaking before their lips are moving)!!!.
Pls help a newbie.
rgds.hilario.
Results 1 to 13 of 13
could you tell us the exact steps and what tools you are using.
and don't convert to avi and then to mpg, convert the mpg directly to dvd and add subs with for example convertxtodvd.
and this is not any advanced conversion. moving you. -
Hi Baldrick:
Sorry I posted at advanced conversion by mistake !!
Ok , as I'm using DIKO which is a free program (CONVERTXTODVD not) I first make a conversion
with MEDIA ENCODER because DIKO wont recognise the MPG file. (AH i must say that I add the subs when transcoding on media encoder) Once I have the Xvid file I follow the normal steps on DIKO to get the VIDEO_TS, and finally burn with Nero.
The result is not too bad but the synchronization is not perfect.
Someone adviced me to use DVD LAB but i found it rather complicated for me to use, and besides that it is also a paid program (useless for an amator like me).
hilario. -
divxtodvd is the old free version of convertxtodvd and it supports externals subs.
if the mpg is dvd compliant can you use dvd-lab pro...but is kinda complicated and expensive.
you could also use dvdauthorgui if the mpg is dvd compliant, demux/split the mpg to video and audio files using tmpgenc, file->mpeg tools, add the video, audio and subs in dvdauthorgui and author. -
Sorry Baldrick, but I dont see where I can add the subtitles on this free version of dvxtodvd.
Are you sure ??
hilario. -
DVD is MPG. You do not need to encode to avi. This is wrong way. -
Originally Posted by Abond
Tried to install but honestly I dont know how to work with it !!.
Maybe too complicate for my knowledge.
tks anyway.
hilario. -
hilario.
Can I burn a .mpg file to a DVD
By robrpb in forum Video ConversionReplies: 4Last Post: 8th Sep 2010, 20:56 -
mpg dvd file?
By just in forum Newbie / General discussionsReplies: 7Last Post: 20th Nov 2008, 21:32 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 13:51 -
Burn MPG file onto DVD
By geek2330 in forum Newbie / General discussionsReplies: 15Last Post: 2nd Oct 2007, 08:51 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 17:52
