Hey,
I want to put the English and the German Audio Tracks on a SVCD. But how to do? I use the Smartripper first, then DVD2AVI to create a .ifo File and a seperate .wav File for TMPEGEnc. But so I got only one Audio Track. How can I get the second one? Thanks for ya help.
u have to encode each audio track seperatly then use a MUX program to mux the video and the audios.
Because you are already using TMPGEnc, you can stick to that program. Just go to the unlock template, and select in the main screen "adio only".
Afterwards you can use BBmpeg or TMPGEnc to mux all tracks together. Please note that your total bitrate can be higher than the SVCD specs.
The Dutchman
movie with two ac3 2-channel audio tracks one is mono, which one?
By pm1315 in forum Authoring (DVD)Replies: 1Last Post: 25th Oct 2011, 13:14 -
How do you do main movie hd-dvd to avchd in multiavchd with 2+ audio tracks
By yoda313 in forum Video ConversionReplies: 2Last Post: 27th Sep 2010, 20:18 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 01:56 -
Original audio tracks for overdubbed movie
By chasethepony in forum AudioReplies: 5Last Post: 20th Dec 2009, 02:44 -
QT movie with 2 video tracks to FLV with mencoder or ffmpeg
By bluehz in forum Video ConversionReplies: 0Last Post: 26th Mar 2008, 15:39
