Results 1 to 13 of 13
    Feb 2006
    NEVER NEVER LAND
    yesterday i was browsing like 10 sites,k then i double clicked on one of the toolbars and they all closed, now ie wont start
    ive deleted all cookies and temporary internet files
    ive run virus scan (and found 2 trojans
    ive run adware
    cleaned my system but ie will still not start
    Feb 2006
    NEVER NEVER LAND
    even netscape wont start, i have 2 use my aol header which is crap
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Tried a repair install ?
    Read my blog here.
    Apr 2003
    Maryland
    Try Firefox instead of IE and see how that works. I don't even use IE anymore except for one sutpid site I have to go on to a pay a monthly bill that insists on IE.
    No DVD can withstand the power of DVDShrink along with AnyDVD!
    Feb 2006
    NEVER NEVER LAND
    how
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Originally Posted by slimpickins
    how
    Maybe buy a PC magazine that has it on the CD that comes with it, or get a friend to DL it and transfer it onto your PC via a USB flashdisk or CD ?
    If in doubt, Google it.
    Feb 2006
    NEVER NEVER LAND
    whats so good about firefox? i can use the net but not open ie, i have to use aol header
  8. Firefox is just another browser, but many people like it due to the flexibility it offers (new themes and extensions). Evidently, you can access the Internet right now (or you wouldn't be posting here) so you could download it and give it a shot.
  9. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Try going to Add\Remove Programs, Windows Components, then untick IE. OK your way out then go back in and tick IE this time. It will probably ask for your Windows install disc.
    Feb 2006
    NEVER NEVER LAND
    d/l firefox, it might not work cos netscape isnt working, il instsll it when my p2p is off
    Feb 2004
    Australia
    The method's to repair :
    Microsoft Knowledge Base Article (#318378), entitled "How to Reinstall or Repair Internet Explorer and Outlook Express in Windows XP" which provides 2 methods of repair.
    I was able to test the instructions on a Win2k machine (as well as my XP machine) and it worked using Method #1:
    To Repair Internet Explorer 6.x (Win2k / WinXP)
    Start -> Run
    Type: sfc /scannow
    Click OK
    Follow the prompts
    Reboot when System File Checker completes
    There is also another method Microsoft describes (Method #2), but it is much more involved and requires editing the registry:
    http://support.microsoft.com/?kbid=318378
    Side Note: Both methods listed require that the Microsoft Windows XP CD-ROM be available.
    To repair Internet Explorer 5:
    Click Start -> Settings -> Control Panel
    Launch Add / Remove Programs
    Go to Install / Uninstall tab
    Click Microsoft Internet Explorer 5 and Internet Tools
    Click Add / Remove
    Click the Repair Internet Explorer option
    Click OK
    For Windows 98 Second Edition:
    The IE Repair tool is not present in Add / Remove Programs (Control Panel) and is only available in the Uninstall Dialogue Box. Gazette Reader Michael W. sent me this information about accessing the IE Repair feature for Windows 98 SE:
    Click Start -> Programs -> Accessories -> System Tools -> System Information
    Click Tools (tool bar) -> Internet Explorer Repair Tool
    Alternatively, you may follow the instructions for IE5.01 (below).
    To repair Internet Explorer 5.01:
    Click Start -> Run
    Type: msinfo32.exe
    Click OK
    Msinfo32.exe tools will open
    Not sure which Internet Explorer version you have?
    The easiest way to find out is to load Internet Explorer, and click Help -> About. The version number should be displayed in the Window.
    Or explore to c:\program files\internet explorer ... right click on explorer.exe , choose "version" tab .
    Microsoft has also provided a much more complex (sure-fire) way of determining what version of Internet Explorer is installed on your system:
    http://support.microsoft.com/default.aspx?scid=kb;EN-US;164539
    Internet Explorer Service Packs
    Service Packs include a wide range of bug fixes and address security vulnerabilities. The download link is below (see: Get Most Recent Version). You can also download Service Packs through Windows Update:
    http://support.microsoft.com/default.aspx?scid=fh;EN-US;ie
    http://windowsupdate.microsoft.com
    Feb 2006
    NEVER NEVER LAND
    ur a legend, i will give it ago and post the results, thankyou so much
