I wish to convert a 20 min DVD onto a CD and can be play on a DVD Player. It is a such a waste of the DVD Disc , especially it only occupies 20 min of playing. How do I go about it . Thanks.
You have a few options, but it depends on what your DVD player will play. There is
1. MiniDVD - basically a dvd spec structure on a CD. Not many players play these
2. SVCD - see What is SVCD (top left corner)
3. VCD - see What is VCD (top left corner). Low res, low quality - use as last resort
4. Raw mpeg. Some players will play raw mpeg1 and 2 files straight from disc. Try this with an RW to test it out.
5. Divx/Xvid. If your player is certified, then this becomes an option.Read my blog here.
What DVD player do you have?
If you look at the price of a DVD blank vs a CD blank. It is a waste of time to convert the video.
Help Converting an ISO Image File into a DVD Format playable on DVD players
By Gradyj in forum Newbie / General discussionsReplies: 5Last Post: 19th May 2010, 21:13 -
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 10th Apr 2009, 00:56 -
Converting/examining my video files and converting to have less pixelated?
By SimpleSimon in forum Video ConversionReplies: 51Last Post: 29th Aug 2008, 00:33 -
Converting .VRO file onto a DVD disc (to play on standard DVD players) ?
By superman123x in forum Video ConversionReplies: 21Last Post: 24th Mar 2008, 18:40 -
Converting songs purchased on itunes and converting to mp3
By maroonx in forum AudioReplies: 1Last Post: 23rd Jan 2008, 01:17
