    Apr 2006
    Hi,all
    Anyone knows how to convert the old 8mm movies to dvd? I found these old movies occasionally in my grandpa's basement. They still play on the movie projector,but i am so curiuos about the way to convert it to dvd?
    Thanks for any info~~~~~
    Jul 2005
    Arizona, USA
    There are services available that will do this for you. Try "Googling" convert 8mm to DVD. Or you could do it yourself. I just projected my movies on a white matte card taped to the wall, and recorded using my camcorder mounted on a tripod. I then edited the video on my computer and add music and titling. The movies actually turned out pretty well. I even scanned a bunch of old pictures and made a slideshow out of them that I included on the DVD.
    Apr 2006
    hi,
    Maybe this can give you some reference.
    http://www.supermediastore.com/tape-8mm-to-dvd.html
