Hi, many of you have already heard my problem. I was trying to edit the text in a motion dvd menu and I used dvd remake to create a still image menu instead. After completing this, I tried to play the newly exported dvd on my computer and it worked fine, I was able to click the part I wanted to watch and my new edit text on the menu was there too. Now when I tried to play the dvd on my home dvd player, I was unable to select the part I wanted to watch because I wasnt able to move the dvd cursor to highlight what part I wanted to watch. As seen in this picture, this is my menu and you highlight the part you want to watch with your cursor. It worked on my computer dvd player but not on my home dvd player. SO can you guys please help me out so I will be able to play the movie on my home dvd player and highlight/select the part of the dvd I want to watch.
Also just to add in, I tried to play the orginal dvd (the one that wasnt edited with my new text) on my home dvd player and I was able to highlight/select the episode I want. It was only after I edited the menu with dvdremake that I couldnt highlight/select the part I wanted, basically making the dvd unwatchable. So any help would be greatly appreciated. Thanks
Someone told me to enable subpicture tracks. Can anyone give me a step by step guide how to enable subpicture tracks in dvdremake pro version 3.4? I am very new to this and just want to be able to highlight the buttons while playing my dvd on my home dvd player. Thanks
Maybe try the manual or the DVDRemake Forums (link is on http://www.dimadsoft.com) ?
Either that or try PM-ing dimad here.If in doubt, Google it.
DVD ReMake Pro! join issue!!
By Shohag_ifas in forum Authoring (DVD)Replies: 7Last Post: 25th Dec 2010, 23:03 -
Blu Ray Authoring version of Dvd Remake? The Space saving Possibilities?
By Moontrash in forum Authoring (Blu-ray)Replies: 0Last Post: 2nd Jan 2010, 15:04 -
DVD back in my PC to remake new movies?
By fishtk75 in forum Newbie / General discussionsReplies: 10Last Post: 23rd Apr 2008, 05:52 -
DVD Remake Pro 3.1.4 issue
By ashoun in forum Authoring (DVD)Replies: 3Last Post: 27th Feb 2008, 12:49 -
DVD Remake Pro deletes my firstplay?
By lordsmurf in forum Newbie / General discussionsReplies: 8Last Post: 18th Jul 2007, 02:10
