I have a 2- hour video that when I load it into MPEGVCR the program splits the video into 4 segments.
When I load those 4 segments in Ulead DVD Workshop 2 the finished authored DVD looks great other than you can see the seams where those 4 segments are joined with a split second delay in the finished video.
Is there a way to adjust the options on MPEGVCR to load the entire movie rather than split it into segments?
You responses are greatly appreciated!
I use Womble all time and have never seen this.
Post a question about this on the Womble Support E-mail.
They have great support. -
I used to have that happen a lot with Womble (Mpeg Video Wizard). I switched to TMPGEnc Mpeg Author and it didn't happen anymore. If I need to add effects or do something else Wombles does that I can't do in TMPGEnc, I load the files in TMPG, create one mpeg file and then load that in Womble.
Nobody seriously recommends using Womble's products for adding effects. MPEGVCR is a terrific video editor, but yes, it sometimes behaves less than optimally if you want to add effects.
Jesse217 - Are you running Windows 98 by any chance? I've used MPEGVCR (well, they used to call it MPEG2VCR) for over 5 years now and I have NEVER had what you describe happen to me. Windows 98 uses the old FAT file system and there are definite size limits to what it supports, which might be why your file is being split. If this is your problem, your only solution is to use Windows 2000 or (better) Windows XP. Sorry. -
Originally Posted by jman98
Hi guys,
Thanks, I am going to try your suggestions.
jman98- No I don't use windows 98, I use XP Pro.
Womble 5 installation question
By netmask56 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Mar 2011, 20:07 -
Womble and HD
By ADigitalMan in forum EditingReplies: 24Last Post: 15th Jan 2010, 01:27 -
Womble Gone?
By cyberboy in forum EditingReplies: 13Last Post: 9th May 2009, 18:08 -
Womble question (MVW / MVW DVD)
By Urvieh in forum EditingReplies: 0Last Post: 20th Nov 2007, 17:31 -
Womble Video Wizard question
By moxiecat in forum EditingReplies: 3Last Post: 21st Jul 2007, 22:02
