I am converting a WMV file to an AVI file in Premiere Pro 2.0. I imported my WMV file and then Exported it as a AVI file. Its taking about 55 minutes to convert this 28 minute movie. Is this a normal speed? Would another program do it faster then Premiere Pro 2.0?
Thanks!
Maybe try Windows Movie Maker ?
Assuming, of course, that you want to convert to DV-AVI.If in doubt, Google it. -
Super , but it also may take time .
Even mediacoder ... but then again ...
You might want to speed up your pc a little , follow this ...
1:
Remove anything running in the system tray that dose not need to be listed (right click them in most case's allow's them to exit) .
2:
Click start , run , type
msconfig
Go to startup tab , and uncheck non-essential startup item's , esspecially those related to printer's and camera's that are not presently connected to the pc , there is no sence for these to be loaded as a default ... the system will call these when needed ... hit apply , ok , reboot .
3:
Right click on start , choose properties ... select clasic menu .
Now click start ... is there anything listed above program file's ... above that line ... the only item's that should be here is ms update , and new office doc (if you have ms office installed) .
Anything above that line use's a very special part of the startup memory ... so it's best to minimize what is allowed up here above that line .
4:
Start - setting's - control panel - system - advanced - setting's - visual effect's , set to "adjust for best perfomance" , apply , ok .
That's speeded up the pc a little for now ...
5:
What antivirus do you have installed ? , if it's norton's ... get rid of it and use another , like avg ... avg has a small memory foot print on system resource's ... norton's will grind any pc down , it's a hog , and has been beaten by avg everytime ... sometime's norton's find's a virus , but cannot do anything about it ... avg will deal with this problem .
This will speed up the pc alot .
After all this , encoding time's should improve ... it's the simplest thing's people miss or have not been told about that can cause long encoding time's .
help converting WMV to AVI
By user943 in forum Video ConversionReplies: 5Last Post: 11th Nov 2008, 10:39 -
Converting .WMV to .AVI - What should I use to do this?
By Hank Kinsley in forum Video ConversionReplies: 3Last Post: 16th Oct 2008, 04:54 -
converting wmv to avi
By evile1690 in forum Video ConversionReplies: 1Last Post: 9th Jan 2008, 04:15 -
CONVERTING FROM AVI TO WMV or RM
By sunsound in forum Newbie / General discussionsReplies: 6Last Post: 19th Jun 2007, 03:17 -
Help converting .avi into .wmv
By Theros in forum Video ConversionReplies: 13Last Post: 5th May 2007, 18:10
