Hi everybody,
It seems I've got a little problem again with my encore DVD. I designed a menu with several titles of chapters, and below a button "main" and "play all", which plays a playlist of all the chapters.
Now, when I open the menu, and I use the arrows on the keyboard to browse trough the buttons, the player does not selects them in the desired order. To reach all the buttons I need to come up with acrobatic skills.. When I open the menu again in Photoshop, all the buttons are in the correct order, and on the "properties" page in EncoreDVD, the numbers are ok as well..
Can somebody help me please?
Thanks!
Did you check the button order in Encore? there is a button to check and change the order of the buttons. I've foiund that I need to do that in order for the correct navegation to take place whicih using the remote.
No DVD can withstand the power of DVDShrink along with AnyDVD! -
Thanks! I found the solution:
Apperently I had to open the menu, than click on a button with 4 arrows below the menu window. Then I had to put off a selection mark in the properties panel, and then the 4 arrows that you can find on the remote of your standalone player were displayed with every link. Simply by dragging lines between te buttons, you can manually set were any of the 4 buttons should point to when pushing the button on a specific link.
Thanks a lot dude!
Jens
encore dvd adobe cs5
By donnaglait in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2011, 06:30 -
Adobe Encore DVD and subtitles ...
By Liru in forum Authoring (DVD)Replies: 17Last Post: 14th Oct 2010, 16:05 -
Burning DVD Encore 2.0
By Usagi Tsukino in forum Authoring (DVD)Replies: 2Last Post: 20th Sep 2009, 13:10 -
Problem in Adobe Encore DVD
By zombie_chan in forum Authoring (DVD)Replies: 10Last Post: 24th Apr 2008, 00:09 -
DVD duration on Encore
By bltprf in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jul 2007, 09:23
