When making a backup of a pressed DVD9 disc do you need to set a layer break like you do with an authored disc, so can you just rip and burn?
You don't need to do anything, I believe (although I have never done this before).
Get DVD Decrypter and set it to "ISO Read". Rip the original. Then set it to "ISO Write" and burn it to the blank. -
Yup that's it...
What We Do In Life, Echoes In Eternity.... -
What a guess!
No..., unless the original DVD9 is a PTP (Parallel Track Path) disc. If so, it's incompatible with recordable DVD+R DL's which are always OTP (Opposite Track Path). If it's PTP, then you'll need to set your own custom layer break if you want to make sure that it plays fine on all the players that are compatible with DL media. It can get somewhat complicated though if there are not enough chapters/cells. Currently there's absolutely no software, including DVD Decrypter/ImgBurn, that is able to make a proper backup of a PTP DVD9 disc (without some manual intervention). I tested it myself. I mean DVD Decrypter will make a perfect copy of a PTP disc, minus the layer break information - and that's where the trouble begins.Originally Posted by stantheman1976
PTP discs are more rare than OTP, but they are still around and the new ones are still being made. If you need a tested method on how to back them up correctly - I'll send you a link. Or simply search for it in my long thread dedicated to DVD+R DL burning and the layer break (it's towards the end of the thread).
How to copy DVD9 with subtitle & Burn it in DVD-/+R or DVD9
By prithvi in forum Newbie / General discussionsReplies: 15Last Post: 19th May 2010, 12:37 -
DVD9 to DVD9 1:1 Copy
By Lastman369 in forum DVD RippingReplies: 5Last Post: 12th Jan 2010, 14:48 -
DVD9 to DVD9 2 angles layer break problem
By JoeBolden in forum DVD RippingReplies: 4Last Post: 14th Jul 2009, 20:17 -
DVD9 to DVD9 blank
By cadlewv in forum DVD RippingReplies: 7Last Post: 27th Dec 2008, 19:15 -
having trouble backing up dvd9 to dvd9
By Chunking in forum DVD RippingReplies: 9Last Post: 13th Oct 2007, 21:34
