Again, the S-Video signal is splitted up in a Luminace signal (just a B/W video signal) and a chrominance signal (the colour information).Originally Posted by kr236rk
To get your desired effect you need a composite and S-Video connection:
Connecting the luminance pins of a S-Video source to a composite input results in B/W picture.
Connecting a composite source to the luminance pins of a S-Video input results in B/W picture.
If you have ONLY composite available you need electronics to split the signal in colour and b/w.
But really, why all this trouble?![]()
Results 31 to 38 of 38
hi,
http://www.lg-internet.com/catalog/images/S%20Vidoe%203%20inch%20to%20Composite%20out.jpg
it works brilliantly from my dvd s-video 'out' to my PCI card RCA/composite 'in' - sharp crisp black'n'white
but do i need twos-vhs vcr's, to turn a colour vhs video into black'n'white?
bests -ric -
Or with a S-Video source connected to a S-Video input with only the luminance pins connected will also result in a B/W picture.
So you need ONE S-Video source or input.
You mention DV, maybe you have a DV camcorder with analog (S)-Video in?
You could use that maybe?
Better still if you captured it to DV you could easily make it B/W on the PC?
Just some thoughts here....
Also because dubbing with VHS will degrade the picture enormously.... -
Originally Posted by The_Doman
lol
thanks Doman -ric -
I believe almost ALL DV camcorders have that feature (S-video out at least), possible you need to have a special lead to use it.
So what is this, a special ART project you have to accomplish with only the use of analoge video??
Intresting it is, I must say..... -
Are you SURE your DV camcorder (which one is it?) has no S-Video input/output?
I believe almost ALL DV camcorders have that feature (S-video out at least), possible you need to have a special lead to use it.] the av
if i hooked up the Canon to a vcr, could i use it as a vcr cam?
thanks for your help and interest - contact me off-forum <kr236rk@aol.com> for example of one of my 'shorts' [15 mins]
bests,ric -
And yes you can use the analog input of the camcorder to record from your VHS video, if you mean that ...
Simple way would be to record your VHS to the DV camera (or passthrough the analog signal directly) to your pc and use a edit/filter program to make your recordings B/W. -
many thanks!ric
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
Converting VHS to digital, VHS tracking problems?
By ReedJohansson in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jan 2012, 09:54 -
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 09:21 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 14:25 -
VHS To Harddrive Via S-VHS VCR & Matrox RT.X100
By westwood in forum Capturing and VCRReplies: 9Last Post: 13th Jun 2008, 08:19
