    Apr 2006
    I Have Clone DVD 2 and AnyDVD.
    I want to make files that i can play on my DVD Player out of some AVI Files on my computer. What do i need to do to ensure that the subtitles are included?
    Also, does the audio automatically insert into the file when i go on browse and select the video folder for a DVD that i have already ripped onto the computer?
    Thanks for your time.
    May 2003
    You need to re-encode the avi's to dvd compliant mpegs before you can make a dvd
    convertxtodvd for avi to dvd with subtitles, add the avi and the subtitle file.
