There are? I sure haven't heard of too many.
Hardsubs are a part of the actual frame data. What's underneath is GONE. Obliterated. You can take the image of the sub and try to overlay it with something, then apply some sort of smoother, but it'll still be quite noticeable. It's not like removing spraypaint. -
Yeah, if you go to "Tools" and type in "subtitles" it will bring up a number of programs, several of which say they can remove subtitles. I was curious about the effectiveness of these programs.
Is there a difference between "closed captions" and "subtitles" if neither can be removed?
No, not in this case. Closed Captions are transmitted as a signal between the frames and is unique to NTSC standard. Subtitles are typically some sort of overlay, not an embedded signal.
subtitles & black bars
By Kiezel in forum SubtitleReplies: 4Last Post: 23rd Jan 2011, 17:44 -
Adding black bars
By ebay in forum Video ConversionReplies: 4Last Post: 7th Aug 2010, 05:37 -
Embedding subtitles on the black bars using
By Earthling2000 in forum SubtitleReplies: 12Last Post: 8th Jun 2010, 08:31 -
Black Bars
By cinnamonhearts2 in forum Newbie / General discussionsReplies: 15Last Post: 30th Jul 2009, 13:44 -
black bars or not?
By Cowabunga in forum Video ConversionReplies: 6Last Post: 16th Apr 2009, 13:56
