Hello,
I searched the forums and I tried to find reviews for this particular tool but I couldn't. Hopefully this is something that's excepted. I was wondering what is the easiest yet best as far as options and quality software program to rip my cd's into mp3 files to burn on a cd-r or cd-rw? If there's already a thread then I would appreciate a link please.
Results 1 to 25 of 25
I'd second CDex - make sure you put in an e-mail address so you can use the CDDB/Gracenote service for naming all your tracks automatically.
Also, if you're planning on keeping tracks on your PC for later playback, why not consider ripping to Vorbis? You'll get higher quality at the same bitrates as MP3. -
well, I want to burn to a cd-r or cd-rw. Would vorbis be able to burn using Nero?
Given that CD audio is 44100hz, what's the benefit?Originally Posted by Bjs
Less stuffing about when encoding in batch mode in besweet to ac3 for dvd's ... as besweet can encode directly from cd's that user's have created , but not commercial cd's ...
Save's you from needing to use "force input to 48000hz" ...
Esspecially when converting 1300+ track's for next dvd project ... -
ok, I'm just looking for more of a simpler program. Something that's quick.
Musicmatch Jukebox. An older version if you can find it. 7.5 works good for me.
Originally Posted by lordmajaxMake your mind up! "best" and "quality" rarely lines up with "quick" and "simple".Originally Posted by lordmajax
/Mats -
ok, I don't want a complicated program. I want something that makes it easy for the user to gets songs from their cd and transfer them to their pc as mp3's. I will be using Nero to burn the music cd.
musicmatch is great. 128kbps mp3 in the free version
Mp3 pro 64kbp in the payware version.
Or in a pinch windows media player - free
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Exactly that is what Nero does in just one click. Look for Encode audio Files.
One should crash the snake and show the wood piece.
[/b]
Nero is good for disc to disc copy of music CDs and for making data CDs and data DVDs but for burning your music files, it sucks.Exactly that is what Nero does in just one click. Look for Encode audio Files.
I just backed up about 300 cassette tapes to CD and I started with Nero but after spending hours and hours of tagging all my albums and tracks only to have Nero ignore all the tags and just burning unknown artist, unknown album, track 1, track 2 etc...I decided to use a program that I was familiar with that I knew would do the job right, Musicmatch.
I also used an audio editing program called Goldwave to split all the tracks from my tapes.
There is an option in this program to batch convert files and I'm pretty sure you can save the tracks off of a CD as MP3. I've never tried it since I only like to deal with uncompressed wave files when it comes to music. -
ok, so i'm gonna try musicmatch for both the ripping and the burning then.
I use Nero 6 for this.
I made a mistake on my last post.
One should click Convert Audio CD´s To Audio Files on Nero 6.
MP3 Recording to CD Software
By SLK001 in forum AudioReplies: 16Last Post: 4th May 2011, 14:42 -
Question about simple software to convert mp3 to burned 74min audio CD
By jimdagys in forum AudioReplies: 5Last Post: 10th Jun 2009, 08:42 -
how to convert MP3 vbr to MP3 cbr?
By sumeshkri in forum AudioReplies: 2Last Post: 26th Aug 2008, 00:59 -
Looking for simple software that will convert mp2 mpa to mp3
By jimdagys in forum AudioReplies: 23Last Post: 20th May 2008, 09:26 -
Free Software to convert mp3 to wav and vice-versa
By UmmAddan in forum AudioReplies: 4Last Post: 2nd Jun 2007, 06:16
