Every since updating to the most recent version of ffmpegX (version 0.0.9w) and the mpeg2enc.intel version deinterlacing causes me to get an error.
The inputs I have used is divx, H.264, and an MPEG4 mov. I have used all of these inputs before and it worked just fine.
This is the error I get from ffmpegX Process:
Encoding started on Sun May 21 02:54:48 EDT 2006
INFO: [yuvscaler] yuvscaler 1.9.0 (15-02-2004) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2004 Xavier Biquard <xbiquard@free.fr>, yuvscaler -h for help, or man yuvscaler
INFO: [mpeg2enc] SETTING AltiVec for MOTION!
INFO: [mpeg2enc] SETTING AltiVec for TRANSFORM!
INFO: [mpeg2enc] SETTING AltiVec for PREDICTION!
movtoy4m
Copyright 2002-2006 Johan Lindstr??m
All rights reserved..
++ WARN: [yuvscaler] Could not infer norm (PAL/SECAM or NTSC) from input data (frame size=640x480, frame rate=24000:1001 fps)!!
**ERROR: [yuvscaler] Uncorrect output keyword: NOT_INTERLACED
**ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: system error (failed read/write)!
Thanks again
Well, never say 'not ever'. You or anyone could write a spec and implementation for 23.976 fps interlaced content. It's just not practical, as interlacing was developed specificly for slow refresh rates on TVs with 29.97 fps (NTSC) and 25 fps (PAL) framerates.
If you can't see combing in scenes with movement (and de-interlace filters off), then you source video must be progressive and doesn't need de-interlacing.
Windows Error - Not Working
By swalih in forum ComputerReplies: 5Last Post: 9th Mar 2012, 14:07 -
KMPlayer and FFDShow deinterlace - how to get "bob" effect working?
By ANOther1676 in forum Software PlayingReplies: 3Last Post: 18th Feb 2011, 07:47 -
mpeg2enc binary not working
By yabastamedia in forum ffmpegX general discussionReplies: 1Last Post: 19th Jan 2011, 12:02 -
ffmpeg.exe has stopped working error when trying to add asset
By skeet09 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 27th Oct 2009, 15:15 -
FAVC..was working now I get error and won't open Why?
By sandman423 in forum Video ConversionReplies: 5Last Post: 27th Feb 2008, 01:09
