Hey, ive had a dvd burner for awhile now and Im getting really frustrated because everything time I try to burn a dvd it reads in my computer but doesnt load on my standalone. So i was wondering im trying to start this over what is the easiest way to burn a AVI XVID file to play on my standalone player. Please LMK what additional information is needed.
I have Nero 6 Ultra Edition
One quick thing to do is to make sure your settop dvd player is able to read the type of blank disc your using. -r is generally more readable than +r though if its less than 5 years old it should read both just fine.
Also what do you mean by xvid file? Do you mean just dragging and dropping it onto the dvd? You can only do that if your dvd player says its DIVX compatible. Then you can do a data burn of the file and pop it in and it will read it. Otherwise you have to convert the avi file to mpeg 2 and author the dvd. You need to read the GUIDES to see how that is done.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Are you converting the AVI file to DVD format first, or just burning it straight to DVD. If you aren't converting it to DVD Format then your set top player probably isn't XVID compatible. Probably easier to just buy a new one that is compatible than it would be to spend hours converting all of your video to DVD format.
-BRETT
How can I Burn DVD using avi file and .srt file as subtitle
By Gayanx in forum Authoring (DVD)Replies: 7Last Post: 15th Jul 2012, 01:56 -
How to burn an *.RM file
By andy jackson in forum Newbie / General discussionsReplies: 1Last Post: 27th Sep 2011, 11:44 -
burn CP. file
By pensioner in forum Newbie / General discussionsReplies: 1Last Post: 13th May 2010, 04:40 -
Trying to Join separate files into 1 file, then add 1 more file and burn
By futureBDburner in forum EditingReplies: 2Last Post: 11th May 2008, 04:50 -
how to burn a BIN File
By Chris 67 in forum Newbie / General discussionsReplies: 4Last Post: 28th May 2007, 08:44
