I have frame sequence that I like to convert to an avi or mpeg file. I want each frame to appear 5 seconds. I want uncompressed RGB because the quality is bad already. Looking for a quick and cheap way to do it. Any suggestion?
Tx
S
Virtualdub? It's free.
http://www.kiva.org/about -
Hi samifox,
Here's how, using virtualDUB:
** first, rename all your .BMP files like this: pic.01.bmp; pic.02.bmp; pic.02.bmp ..
** then, startup vdub
** then, in the folder that has all your .bmp files, using the first one, pic.01.bmp,
drag that one into vdub's window. It will *append* any remaining .bmp sequence so long
as they all follow the same name and index number order.
( When working with this type of index sequence stuff, it is best to work
with double-digit or longer, numbering.. ie, pic.00 or pic.000, etc. This also
help with the sorting of numbers. )
Finally, you can frameserve this into most RGB ready mpeg/divx type encoders.
-vhelp 3947 -
Thank you very much
This is expertly what I was looking for. The only thing that left out of your reply is how do I control each frame show?
Tx
S -
Handy with AviSynth?
LoadPlugin("C:\Path\To\ApplyEvery.dll")
ImageSource("%d.bmp", 00, 999, 30,pixel_type = RGB24)#adjust for number of pics (this opens 1000 BMPs at 30fps), pic format (jpeg, maybe) or framerate (24fps?)
RepeatEveryFrame(150)#if 30fps, repeat each frame 150 times, part of ApplyEvery.dll
AssumeFPS(30)#slow back to 30fps so each frame shows for 5 seconds
http://www.avisynth.org/ImageSource
http://www.avisynth.org/stickboy/
I haven't had much experience opening a bunch of pics, so I couldn't test that. You have to point a path to the pics, inside of the ImageSource quotation marks. Fool around with it and you should get it. Test the script in VDub(Mod) before sending to your encoder. The RepeatEveryFrame and AssumeFPS I tested, and they do take a 30fps source and make each frame last for 5 seconds by playing each frame 150 times at 30fps. There are also other ways to accomplish that, but this is a pretty easy one. It's already in RGB24. Just drop the script into your encoder of choice. You might adjust the pixel_type for the encoder. Leave it alone for TMPGEnc, use YUY2 for CCE, etc.
Corel DVD Movie Factory: What does it mean function calling sequence?
By ausrele0505 in forum Authoring (DVD)Replies: 5Last Post: 13th Feb 2012, 03:54 -
Easy Question..Make duplicate of movie DVD
By WareISChris36 in forum DVD RippingReplies: 4Last Post: 23rd Jul 2011, 14:43 -
Image sequence and easy x264 GUI
By Bucic in forum EditingReplies: 5Last Post: 4th Oct 2010, 16:03 -
Sin City - movie over 50 seperate m2ts files - not all in sequence.
By Z.Sath in forum Blu-ray RippingReplies: 5Last Post: 11th Jun 2009, 15:45 -
best compression for image sequence movie ??
By mehdi0016 in forum Newbie / General discussionsReplies: 6Last Post: 26th Dec 2007, 09:17
