how do you stop the tracking text coming up,
when your recording a video to a 'stand Alone' - recorder...
anyone know?
it's when the video is adjusting it self, the message comes up for the tracking
I usually let it track, then picture search back to the beginning and start recording. You can turn the on screen display off on some machines, some you can't.
Ok, Got it. On a RCA I used to use the display button on the remote to disable on screen messages. On the JVC I'm using now it is a menu setting to display or not.
Another way is that most VCRs can be changed to Manual tracking mode and that will surpress the message too. You will need tha manual for that as it isn't intuitive on most units how to do. -
How did you remove this on the JVC (I have an HR-S9800U without remote). All VCR status information (e.g. calibration, tracking) goes to the TV, which I obviously don't want when I'm recording to DVD.
Optimal tracking for video != optimal tracking for audio
By miamicanes in forum RestorationReplies: 4Last Post: 16th Oct 2014, 12:52 -
Read text create audio and convert text to synced subtitles in mp4
By Philip Lean in forum SubtitleReplies: 1Last Post: 25th Feb 2010, 09:54 -
mpeg2enc file is coming up as text
By cteavin in forum ffmpegX general discussionReplies: 4Last Post: 26th Aug 2008, 20:13 -
looking for good OCR software that will convert text in jpg to regular text
By jimdagys in forum ComputerReplies: 6Last Post: 27th Jun 2008, 11:38 -
C# code to save text from listbox to a text file -- SOLVED--
By freebird73717 in forum ProgrammingReplies: 2Last Post: 2nd Sep 2007, 16:50
