I need to be able to capture portions of recorded DVD's I have in DVD mpeg format so I can piece the portions together using TMPEG DVD Author. But I dont know how to capture portions of the DVD into DVD mpeg in the same manner I can capture portions of VHS through my ATI ALL-IN-WONDER card straight to DVD mpeg using the composite out.
Can I use the same composite out and hook up my DVD player and record the portions I want? Is there other ways?
Thanks!
Forgive my stupidity...
If I used TDA to pull the pieces of video out of each DVD, the final output of each piece comes out as a full DVD file using the Output option with TDA, ready to burn. HOw would I get all these pieces together into one compiltation?
Can TDA output in DVD mpeg form? -
I'm not sure exactly what you're trying to accomplish, but it if you want to take several DVD's, extract clips, then re-author a new DVD then TDA can do that. ADD DVD Video to bring in each full DVD, edit each clip down to size, create menus and burn.
If you want to make mpegs from your DVD's then TDA can do that too: https://forum.videohelp.com/viewtopic.php?t=224833#tmpgencdvdauthorereauthor"Art is making something out of nothing and selling it." - Frank Zappa
How to capture gameplay from XBOX360 to AVERTV capture card
By Ollie999 in forum Capturing and VCRReplies: 2Last Post: 25th Oct 2011, 21:16 -
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 12:42 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 05:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 19:05 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 20:42
