Results 1 to 10 of 10
    May 2006
    Hi all,
    I just purchased a Panasonic DMR-ES20 DVD recorder to transfer my digital camcorder movies to DVD via firewire. I was disappointed to find, in the manual, that the unit will only record to the 4:3 aspect ratio, unless you use a DVD RAM disc. My camcorder tapes are all recorded in the 16:9 format. Do all standalone DVD recorders have this same shortfall? Also, when I eventually get a DVD burner for my PC, will I have the same limitations?
    Thanks for your help.
    Mike
    St. Louis
  2. I have an ES45V with the same limitation. I was thinking of recording a tape to RAM then reading the files off on the PC (if my Pioneer 110D can do that) and making a DVD-R.
    Panasonic DMR-ES45VS, keep those discs a burnin'
    May 2006
    Thanks for the feedback. So are you saying that when I burn DVD's on my PC, I will be able to retain the 16:9 aspect ratio?
    Thanks.
    Mike
    St. Louis
    You could also record 4:3 on the dvd recorder(it will look stretched) and then copy it to the pc and burn a new dvd with 16:9 using for example ifoar2ws.
    May 2006
    Thanks, Baldrik. One more question: Should I look for another DVD recorder or will they all only record in 4:3 format?
    Thanks again.
    Mike
    St. Louis
    Dec 2003
    Eugene, Oregon
    The Pioneer recorders automatically recognize a 16:9 video from a camcorder via either the DV in or S-video. I've done this with my first-generation DVR-510H-S and it hasn't changed with later models. Toshiba recorders I'm told have a setting where you choose the aspect ratio. Sony recorders are good for 16:9, too.
    As noted by Baldrick there are ways to fix the 16:9 flag using your computer. Aside from the hassle that's no different than the recorder getting the flag right to begin with.
    Nov 2000
    Canada
    So...use a DVD RAM disc. I don't see a problem. Cheap and re-useable 100,000 times. Been doing this for a little shy of 4 years....
    May 2006
    Yes....I know that I can use a DVD-RAM disc, but I will not be able to share the video with my friends and family, since they will not have the capabilty to view on their DVD players. Unless, I'm wrong?.....
    Thanks.
    Mike
    St. Louis
    Nov 2000
    Canada
    Do you have a DVD ROM drive in your computer? I have old ones that will play the DVD-RAM from the recorder. You can then strip the VRO file out and author a DVD with TMPGEnc DVD Author, or since you don't have a burner, make it into a VCD or SVCD that will play in your friends and family's players. If you aren't doing any editing, it only takes a few minutes. Some DVD players will play RAM but usually only Panasonics accept them. I don't understand...you don't have a burner? They are as little as $30 these days. That means practically anyone can afford one, even someone like me who is semi-retired.
  10. Sony RDR-GX300 can do it. Limitations:
    DVD+R(W): only 4:3,
    DVD-RW (VR mode): automatic mode,
    DVD-RW (video mode), DVD-R: "Rec screen size" must be set to "16:9" BEFORE start of recording, limited to full resolution formats (2 hours or less on 1 disk).
