I am using Scenarist built-in AC-3 Encoder to convert uncompressed 48 MHz audio files to
DVD compatible *.ac3 format.
While this built-in converter doesn't have much of settings the documentation doesn't cover it very well.
I had nothing to do but to try some different combination of the settings. Some of the settings names are self-explanatory. Some are not. Doesn't matter how many times I tried the sound on final DVD appears to have no bass tone (most of the sound is just pop music from 70th).
I tend to believe that is me who messed up the setting. I am apparently not using proper adjustments. Besides it, the software I am using is rather old. I wonder if recent releases of Premier Pro or After Effects with support of DVD authoring would do a better job encoding audio.
If so...would you please share your suggestions on best settings.
Thanks in advance!
Perhaps this will help:
http://forum.doom9.org/showthread.php?t=56020
I have personally tested the Sonic Foundry 5.1 Plug-In Pack for ACID Pro, as well as Sonic Foundry Soft Encode. These methods should also work for BeSweet, Vegas Video + DVD, Scenarist, and other software-based encoders.
Best settings for anime encoding?
By The Scenes in forum Newbie / General discussionsReplies: 5Last Post: 14th Dec 2011, 18:28 -
Reading Encoding Settings
By dogar in forum Video ConversionReplies: 5Last Post: 8th Dec 2011, 06:30 -
Copy encoding settings from the video?
By Charmer in forum Video Streaming DownloadingReplies: 1Last Post: 14th Apr 2010, 09:59 -
Which software to use and best settings.
By simoupnorth in forum DVD RippingReplies: 12Last Post: 10th Jan 2008, 16:54 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 00:31
