I'm in my 1st few weeks of attempting to convert my videos to DVD format. I have been copying them via SCART from my VCR onto DVD+RWs using a LiteOn (LVW-5115GHC+). I then put said DVD into my PC DVD rewriter and fire up Nero Vision. If I simply skip through the wizard without attempting to "Edit DVD Title and Chapters" it appears to work fine. However if I do attempt to add or alter the chapters when I put my DVD back into a DVD player (PC or TV) (even though the data is on the disk) all I get is a dead dumb menu that doesnt link to the actual video. Does anyone know how to solve this![]()
Also although Nero boasts to have a "DVD Shrink" type thing in one of its many sub-programs "ReCode DVD" (or something like that) it doesn't appear to kick in if a project using NeroVision gets slightly too large for burning. It's VERY anoying after spending hours playing VHS onto a DVD for Nero to add a few Mb and it not to fit onto a single DVD anymore. Is this a "User Problem" or a generic limitation of Nero![]()
Also When I save a NeroVision project it saves it as an NVC file which only appears to open through Nero Burning ROM so I cant re-edit or re-burn if there are problems and it doesnt actually save the project data!! Any Idea why this is and is there any easy solution to different DVD editing, encoding, burning software saving with file extensions that other packages dont recognise![]()
Sorry for long question and if I'm asking numpty questions but help would be appreciated!
Cheers![]()
Results 1 to 1 of 1
Having PROBs with internet connection, this is what I've done so far. Help!
By jacknscoob in forum Off topicReplies: 10Last Post: 19th Feb 2012, 04:37 -
I'm having probs with MPC-HC
By HartsVideo in forum Software PlayingReplies: 8Last Post: 10th Feb 2011, 21:47 -
A few probs with FAVC
By kronick in forum Video ConversionReplies: 9Last Post: 15th Oct 2008, 20:25 -
sync probs with dvdx
By zookeeper525 in forum AudioReplies: 0Last Post: 18th Aug 2007, 23:28 -
dvdx sync probs
By zookeeper525 in forum DVD RippingReplies: 0Last Post: 17th Aug 2007, 21:29
