ffmpeg.exe Application Error: "The instruction at
0x00470c15" referenced memory at "0x000000f", Thee memory could not be written.
overheating issue? Or is it just a one off source?
I thought about the overheating, but it stopped 3 times at the same point. I also checked the processer fan and left the side cover off.
I'll try another avi file to see it it does the same thing. -
Guess it is just that one file. Had no problem processing the next avi. I just installed sd2 on my new computer and the error occured with the first file I tried, guess I should have tested several before I posted.
Frame Processing
By keithnut in forum EditingReplies: 8Last Post: 31st Dec 2012, 11:28 -
Batch Processing
By keefytee in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 7th May 2011, 05:41 -
Need help with sync problems during processing
By Jon.G in forum Authoring (DVD)Replies: 23Last Post: 6th May 2011, 05:14 -
Post-conversion processing?
By ktwbc in forum ffmpegX general discussionReplies: 1Last Post: 8th Jan 2009, 14:16 -
Batch Processing
By ruggie_uk in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 19th Jul 2007, 07:04
