I've never had a problem with Super until now. I've used it to encode an entire movie in WMV format to AVI. But now I'm having a problem converting a WMV file to AVI. It encodes the file normally, but when I play it in WMP10, it is totally whacked. It's hard to even describe. The file is extremely choppy and looks like someone's playing a DVD on Fast Forward X32. The timer jumps right along with the scene, going from 2:32 in one second to 3:45 in the next. When I try to fast forward the clip, it looks like it says that the clip is 19 hours long. I tried another WMV file and it did the exact same thing. What should I do? Here is the info on the file
Video #0
Codec/String : WMV3
Codec/Info : Windows Media Video 9
BitRate/String : 515 Kbps
Width : 640
Height : 480
AspectRatio/String : 4/3
Audio #0
Codec/String : WMA2
Codec/Info : Windows Media Audio 2
BitRate/String : 64 Kbps
Channel(s)/String : 2 channels
SamplingRate/String : 44 KHz
In super encoding , dont adjust frame rate ... just convert wmv straight to avi .
Gspot may beable to show true frame rate of wmv file .
Open avi in vdub , go to file , file info , check frame rate is match of original wmv .
If not , go to video , framerate , set to original frame rate from wmv file .
Setup audio encoding and compression ... setup compression for video ... save as avi (another folder)
Use Guiffmpeg to do framerate conversion to required rate ... or ulead video studio se (ebay = cheapo) , has the best frame rate conversion I have seen for such a cheap price .. it cover's alot ... what it dosent , is backed up with freeware here in tool's section .
As you have found out ... pc's with the right decoder's installed will play any framerate ... other device's will not . -
I'm actually kinda lost. I couldn't get the framerate from GSpot. The file is in WMV format, so I can't open it in virtual dub. If anyone could give me some clearer instructions, I'd appreciate it.
What is AVI(for pocket PC) in Super?and keep aspect ratio in Super ?
By SingSing in forum Video ConversionReplies: 2Last Post: 19th Dec 2009, 22:05 -
Problem installing Super
By Garibaldi in forum Video ConversionReplies: 7Last Post: 6th Jan 2009, 13:20 -
problem converting to mp4 with super
By cduval04 in forum Video ConversionReplies: 2Last Post: 16th Dec 2008, 12:42 -
super dvd player problem
By thecrock in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2008, 15:53 -
Problem with SUPER when converting RM to any format...
By hzgg2 in forum Video ConversionReplies: 1Last Post: 22nd Apr 2008, 14:32
