I'm having a big problem with AC3 Machine. I get a DOS screen that flashes up and nothing happens when I'm trying to deal with the audio.
On the video side, what are the specific things we're supposed to be "checking off" on TMPGenc? When I load the script, it doesn't seem to do anything that I couldn't do with TMPGenc myself.
Originally Posted by digitalfreaknyc
Well actually you still have to use DGMPGDec/DGIndex along with DGPulldown but you do not have to use AviSynth. I still prefer the AviSynth method but I wrote the new guide for those that do not want to learn how to use AviSynth.
Here is a link to the new guide ---> CLICK HERE
The benefit of using DGPulldown is that the new NTSC video will have the same running time as the original PAL video so there is no need to adjust the audio.
John,
I need to adjust the audio. That's the entire reason I want to do it. I can't stand the speed-up. -
digitalfreaknyc,
If you have a question to ask, please create your own thread as opposed to posting in a two year old one. It means you are more likely to get an answer, and it makes searching easier for those with the same issue in the future.
Many thanks!
Cobra -
I don't think so. If you want to play with some advanced stuff and still have a (more or less) understandable GUI try this:
http://forum.doom9.org/showthread.php?t=110596 -
I actually fixed the problem.
For those who have been having problems with ac3machine...make sure all the programs (besweet, ac3machine) are all in the same file on your pc.
Also, as Fulci mentioned in another thread, make sure you use the BETA version of Besweet because you can get pops otherwise.
High-Performance machine taking 20+ Hours to Encode AC3 audio.
By Joe Hill in forum Authoring (DVD)Replies: 9Last Post: 25th Feb 2012, 10:30 -
3 year old compaq laptop goes black and does not respond to any input
By ryangarfield in forum ComputerReplies: 3Last Post: 19th Aug 2010, 08:59 -
Authoring so that my standalone DVD player can respond to remote control
By cprelude in forum Authoring (DVD)Replies: 3Last Post: 22nd May 2008, 12:03 -
New Computer Screen Won't turn On, and CPU Doesn't Respond Either
By kerrex_2006 in forum Newbie / General discussionsReplies: 16Last Post: 22nd Nov 2007, 05:25 -
S-Video output wont respond
By dubmunkey in forum ComputerReplies: 5Last Post: 12th Jul 2007, 03:28
