Ive been using a programme called: MPEG Encoder to get my .avi files into MPEG format. and then TMPencode to put the MPEG files into Pal to put onto a DVD disk!
It's worked fine for 12 .avi's but now im left with 2 .avi's that won't convert into MPEG / Pal for a DVD disk!
Anyonek now what the problem is?
Closed Thread
Secondly, your current process is highly suspect. Why use an mpeg encoder to encode an avi file, then use a different mpeg encoder to convert the format ?
Start with details, and try to be accurate. Use g-spot to get the details of the avi files so we know what source you have. Use the correct names and spelling for the software you are using. There is no TMPencode, however there is a tmpgenc. If that is what you mean, please say so.
The vaguer you are, the less help you will get, simply because all we have to go on is guesses.Read my blog here.
4CC: southcliffapartments@theseaside.co.uk
IMRR: 1.00
I/L: 1 vid frame (40 ms) Split: Yes
Is that enough info?
Sounds like you are bringing in files in various formats, and then wanting to convert them to MPEG2. If your beginning file is already DIVX, you want something that converts from DIVX to MPEG. If you file is AVI or DV-AVI, you want a different tool for that. You first need to figure out all the different file types you will be working with, and then use the search function, or browse the forums to figure out which tools will work best for what you want to do. Before you can do anything, you first need to know what you have to start with, and what you want for the end result. Then you can figure out the way to get there.
Rob
Slight prblem with noise.
By Jimbo1 in forum Video ConversionReplies: 1Last Post: 25th Jun 2011, 08:57 -
Slight Hauppauge HD PVR Issue
By octaneflame in forum Capturing and VCRReplies: 4Last Post: 10th Feb 2011, 16:46 -
Question about slight 1 second jerk when camera pans
By jimdagys in forum Authoring (DVD)Replies: 31Last Post: 5th Apr 2009, 08:39 -
Slight problem with GOM Player
By jonghyunchung in forum Software PlayingReplies: 1Last Post: 22nd Oct 2008, 02:04 -
Slight problem when hardsubbing in a batch
By bmwracer in forum Video ConversionReplies: 1Last Post: 25th Jun 2007, 17:32
