I usually use VDubMod to do that, but it doesn't work with new mkvs. The only option is avs but quality drops a lot :(. Anyone knows if there's a way to process h264 video stream masking the frames I want, and directly put it to another file? Even at keyframes would be fine.
I do it for all tv series, to mask op/end and still have the same video timecode(for ext subs/audio/compatibility etc). Before that I was cutting the videos but now I like it this way.
I managed to do that. If anyone's interested - here are the steps i took -
1. split original mkv using mkvtoolnix (mmg.exe, split at timecodes)
2. open one of resulting files in vdmod (errors because of vfr, no picture at all)
3. select everything but first and last frame
4. mask and save.
5. merge everything back into one file.
And here it it - same times, no openings/closings, size is -50mb compared to orig.
drop half of the frames without reencoding
By mathmax in forum Video ConversionReplies: 4Last Post: 11th Apr 2012, 16:39 -
Need to convert h264 avi to mp4 without reencoding, help?
By chupacabra24 in forum Video ConversionReplies: 2Last Post: 30th Oct 2011, 12:02 -
Cut HD files (h264/avc) without reencoding
By cd090580 in forum EditingReplies: 3Last Post: 25th Jun 2010, 18:37 -
Are you able to insert blank video into hd h264 without reencoding?
By yoda313 in forum EditingReplies: 2Last Post: 5th Jun 2010, 23:42 -
whited frames on generated h264
By marcio.sfs in forum LinuxReplies: 4Last Post: 5th Jun 2007, 14:48
