I have a WMV file that i wanted to convert to AVI, it includes a segment in the beggining with a logo of the person who encoded the file it also has a little music with it, and it takes about 3 seconds of the beggining of the file, i wanted to cut it using virtualdub, but it cause the audiosync problem, and the audio stopped being synchrinized with the video, btw, even if i do not cut this segment away and just convert it as it is, the audio problem still exists, can someone help me with this, is there a way to avoid this?
just don't tell me that i can fix it with this "preload" option in VB, i tryed this but it doesn't help.
virtualdub doesn't support wmv....or have you converted to avi already? or using virtualdub-mpeg2? or how?
try convert the audio to a wav, in virtualdub open the wmv, audio->full processing and file->save wav. then use that wav as audio source, audio->wav source. it often fix audio sync issues for vbr audio.
you could also try cut the wmv with asfbin, steeper, asftools and then convert it.
Mkv Audio sync problem converting to DVD
By yudopplyr in forum Video ConversionReplies: 14Last Post: 10th Dec 2011, 14:55 -
Loss of Audio Sync after cutting (Avidemux)
By Maverick-X in forum EditingReplies: 4Last Post: 14th Oct 2011, 15:12 -
Problem with audio sync with an mp4/converting an mkv.
By Clowmet in forum Video ConversionReplies: 0Last Post: 21st Aug 2011, 08:58 -
Audio/video/subtitle sync problem converting MKV to DVD (Muxman issue?)
By crackerbear in forum Authoring (DVD)Replies: 3Last Post: 7th May 2010, 11:23 -
Audio sync problem converting 2nd part VOBs->avi with VDubMod [fixed]
By blueprint in forum Video ConversionReplies: 5Last Post: 13th Dec 2007, 00:07
