Hi,
I have a mpeg2 with too long video gop. The authored DVD doesn't work well when fast forwarding the picture, so I decided to fix the gops. I think I solved that problem with Procoder several times in the past, I'm not sure, but the thing is now it doesn't work.
I reencoded the mpeg2 with Procoder using these options:
Number of Frames in a GOP: 15
Distance between I/P Frame: automatic
Use Sequence Header Interval every GOP
I reencoded twice, one with no closed GOP and the other with closed GOP. I think closed GOP option is no relevant for the number of frames problem, but I didn't know if that could be the cause of the wrong reencoding. Anyway, both times the reencoded GOPS were 30 frames long, even longer than the original ones, that have 26 frames.
I don't know what else to do to fix that mpeg2. I can try with CCE but would like to know if there's a way with Procder.
Thanks in advance.
Results 1 to 1 of 1
DVD video has Too Long GOP, What To Do
By Brent212 in forum Authoring (DVD)Replies: 5Last Post: 14th Aug 2013, 08:36 -
How to fix long VOB seek times
By aliasx51 in forum Newbie / General discussionsReplies: 9Last Post: 2nd Apr 2008, 12:02 -
VCD to DVD (TDA error: GOP too long)
By jelir in forum Authoring (DVD)Replies: 1Last Post: 6th Jun 2007, 09:40
