The video quality isn't so great since it was taken from a vhs recording of an event. Anyway to fit all of it on a single layer dvd, its in xdvd format.
Results 1 to 9 of 9
95% of most questions can be answered with a search but I'll be nice and say dvdshrink
but isn't xdvd standard dvd in tmpgenc? just lower video size/resolution.
did you try choose dvd ? and be sure to use compressed audio like ac3 or mpa/mp3. if you use 192 kbit/s audio the video bitrate should be around 3100 kbit/s...you could lower the video size/resolution to 352x576. -
Will the quality suffer alot???
with dvd shrink, I would burn the dvd to dual layer then copy it into a single layer format??? -
it's better to convert to correct size directly instead of dvd shrink it.
am i better of just going with a dual layer dvd, cause there is alot of dancing in the video so i would think it needs a good video bit rate
I'm massively confused: Want to fit about 2 hours worth of video on a DVD
By karlcward in forum Video ConversionReplies: 2Last Post: 21st Oct 2010, 17:51 -
Converting Dual Layer DVDs to AVI (Video Footage More Than 2 Hours)
By cucuzza in forum Video ConversionReplies: 2Last Post: 17th Sep 2010, 18:54 -
20 Hours on a single DVD?
By Alienverse in forum Authoring (DVD)Replies: 45Last Post: 26th Oct 2007, 13:11 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 13:39 -
What Is The Best Way To Fit 2 Hours On A DVD?
By Anakin in forum Video ConversionReplies: 14Last Post: 4th Jun 2007, 11:52
