Hi, I'm not sure if I was suppose to post this in the newbie section or this one because this is an audio-related problem. I don't seem to have this codec for some reason :O!!! I don't know where to get it other than to download the ACE mega-codec pack, but that pack makes all my videos play with horrible quality. Can anyone help me? Thanks
** I also tried to install ACE mega-codec pack and by unchecking everything except for this codec, but it still affected my video quality.
Again, thanks for the help
- DouMing
You can get the whole MS codec package here: http://www.codecguide.com/download_other.htm
The 'Windows Media Lite' program should replace it. I believe it also comes with Windows Media Player. It also may be part of the XP install, as I don't have WMP and I have it on my computer. -
Is it the Windows Media Lite?
I downloaded it, and installed it, and it still doesn't work.
Do you mean another?
**Ohh, so I should install ACE codec pack, and then install this afterwards? -
I wouldn't install a codec pack. They can be the cause of more codec problems than they cure.
You can DL the common Windows audio codecs from MS here:
http://www.microsoft.com/windows/windowsmedia/download/AllDownloads.aspx?displang=en&qstechnology=
I'm not so sure a missing codec is your problem, though. Have you checked in 'Control Panel>Sounds and Audio Devices>Hardware>Audio Codecs>Properties>Properties' to see if it's there? -
Yeah, I checked that and I didn't see the Windows GSM 6.10 Codec on the list, so I know I'm missing that. But I installed the ACE codec pack and then the one you gave me, and it's working.
Thanks =)
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Trying to Install Microsoft MPEG-4 Video Codec V1, V2, V3
By eon_designs in forum Video ConversionReplies: 2Last Post: 10th May 2010, 13:03 -
Microsoft DV Avi codec - lossy?
By branch in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 4th Mar 2008, 23:27 -
Microsoft WST Codec filter & Hauppauge Remote?
By amdk62 in forum Newbie / General discussionsReplies: 6Last Post: 18th Dec 2007, 11:21 -
Microsoft: Free and open source software violates 235 Microsoft patents
By rkr1958 in forum ComputerReplies: 32Last Post: 11th Jun 2007, 23:36
