Thread: VirtualDub "xxx.dll not found" errors...
  1. #1
    I have downloaded VirtualDubMod 1.5.10.0
    when i click on this app it shows me this Error message
    "corona.dll" not found,i downloaded it.
    Now when i click it shows me this mess "ogg.dll" not found,downloaded that too.....
    Again it shows this mess"vorbis.dll" file not found ,downloaded that toooo.
    Now when i click it shows no mess nor the tool open nothing happens ?
    whatz this prob plzz help me
    Please start a new thread if you have a new question, as opposed to posting in an old thread.
    I'm afraid I cannot help with your problem. Sorry!
    Many thanks, and good luck!
    Cobra
    VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Posts
    4,756
    If you've downloaded the full VDubMod package (as opposed to any of the 'update' or 'patch' releases which may only include the main .EXE and one or two text files in the ZIP archive), make sure you have your unzip utility set to extract all the directories within a zipfile (properly) as well. If not, some unarchivers will just leave the directories and their contents alone, and only extract everything else in the ZIP.
    If you can open the ZIP file with your unarchiver and look at the contents, or have WinXP and use its ability to open ZIP archives as folders, do the subdirectories and those files (corona.dll, etc.) exist in the archive?
  1. DGindex "NO video sequence header found"
    By JackDanielZ in forum Video Conversion
    Last Post: 28th Apr 2012, 08:41
  2. Replies: 3
    Last Post: 30th Dec 2011, 07:48
  3. AVStoDVD does not start... says "VB6 Common Controls not found!"
    By granturissimus in forum Newbie / General discussions
    Last Post: 12th Jan 2011, 07:15
  4. Replies: 0
    Last Post: 8th Jun 2010, 07:17
  5. BR structured image file is found as "unsupported"
    By besthost in forum Authoring (Blu-ray)
    Last Post: 28th Jun 2009, 02:06
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
