I am looking for a nice camcorder, spending $1,000-$1,500,,,
should i buy a hdminidv or just minidv?
i will be editing the videos.
i would think hdminidv since hd dvd players are going to be the future right?
and good camcorders you can recommend?
thanks in advance
Umm do you mean HD=High Def or HD=Hard Disc?
MiniDV is Standard Def 720x480 (DV format)
HDV is a High Def (1440x1080i or 1280x720p) MPeg2 based format.
HDV camcorders often record DV format as well. The same tape is used.
For $1,000-$1,500 you could afford a 3CCD SD camera (like the Panasonic GS-400 or 500) or a single CMOS sensor HDV (like the Sony HC3)
See www.camcorderinfo.com for reviews. -
its HD=High Def minidv,
would it be better to buy the HD=High Def minidv
since thats the future?
a appreciate your help. -
The HC3 makes a good picture in standard DV format as well but not as good as the GS-400. If you intend to watch mostly on a high end HDTV, the HC3 will be your best bet long term. HDV will have the disadvantage of much slower processing (editing, effects, filtering, encoding) on a computer. Also, you will need to invest in a HD DVD player and authoring system unless you just play the tapes from the camcorder.Originally Posted by gomez1
HDV will be the mid level high def format for a few years. A new MPeg4 based format AVCHD has just been announced for future delivery. I think it will be a couple of years before that format is competitive with HDV.
http://www.camcorderinfo.com/content/Sony-and-Panasonic-Announce-Blu-Ray-High-Definiti...der-Format.htm -
since u have money to burn .check the PANASONIC AGDVC30 Proline Mini DV Camcorder
http://www.amazon.com/gp/product/B00028SR0A/ref=pd_cp_p_title/002-7622935-8293657?%5Fe...lance&n=502394
Cap from minidv HD
By bts1018 in forum Capturing and VCRReplies: 5Last Post: 19th Jul 2011, 09:56 -
Convert from MiniDV to PC
By Tigerjon in forum Video ConversionReplies: 22Last Post: 12th Apr 2011, 22:44 -
MiniDV Recorder
By luckyo in forum Capturing and VCRReplies: 3Last Post: 9th Nov 2010, 07:07 -
Looking for new minidv camcorder. Panasonic miniDV or other?
By latin trident in forum Newbie / General discussionsReplies: 7Last Post: 22nd Oct 2008, 16:54 -
miniDV to hard drive to miniDV while preserving time and date?
By vid83 in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2007, 22:46
