I can't seem to get rid of the Pause between tracks when I try to record a seamless mix from CD. I've tried Nero, Musicmatch, and Windows Media Player. Any suggestions of a program that will do what I need? The above mentioned do not do justice to my music. I prefer Freeware, but any suggestions would be appreciated, as my stand alone CD recorder is down at this time.
Thanks,
Results 1 to 11 of 11
cdrdao is the best for gapless audio burning. There's a howto at the home page of the app. Completely free.
/Mats -
In Nero, right click on the track, select properties and change the Pause from 2 seconds to 0. Do this with all tracks then burn as normal. By default it gives you a 2 second pause between tracks.
I've never succeded this whithout a slight (but noticable) moment of silence between tracks.Originally Posted by Richard_G
/Mats -
Prassi Ones
session at once - closed
Keep in mind that with a live concert CD that was designed to run through with no audio breaks between songs....session at once/disc at once was designed to replicate this type of disc.
Taking individual songs will result in a slight pause no matter what you do....short of editing the beginning and end silence off of each song then joining them together prior to burning. -
That's because there is a slight silence on the actual lead and out of the audio track itself. You would have to cut those parts out in an audio editing software and re encode to a new file. Then you could tell Nero or whatever to not put a gap between songs.'ve never succeded this whithout a slight (but noticable) moment of silence between tracks.
Actually unless they are all the same Key or Tempo beats/per/second it would not be such a smooth trasition even without any silence gaps. A perfect mix would blend in pitch
( Key Signature ) and beat or tempo so it would amoothly transition for song to song just like at a good disco.No DVD can withstand the power of DVDShrink along with AnyDVD! -
...or a live recording (which is what I've used it for).
/Mats -
I'm not familiar with Nero but what you want is Disc At Once or DAO.
Are your source files mp3? Mp3 encoders are not sample accurate. I have found that they add about 4000 samples to the original file. At nearly a tenth of a second this delay is quite noticeable.
Recording video from one computer to another
By tshirttoby in forum Capturing and VCRReplies: 4Last Post: 17th Feb 2011, 22:08 -
Getting the dvd recorder input incorporated into the mix for recording
By duckman in forum Newbie / General discussionsReplies: 3Last Post: 16th Jun 2010, 00:41 -
By MGadAllah in forum Video Streaming DownloadingReplies: 10Last Post: 10th Dec 2009, 19:53 -
Blackmagic Intensity OnAir 2.0 stereo-mix recording?
By Martz in forum Capturing and VCRReplies: 0Last Post: 23rd Feb 2009, 04:32 -
recording tv from my computer
By brenjim in forum Capturing and VCRReplies: 24Last Post: 5th Jul 2007, 10:14
