Converting the avi file with TMPGEnc didn't work so I tried converting it with LSX MPEG Encoder. When I load the file, it says my avi file has a frame rate of 4294961.423 frames/sec (under the avi file properties screen)..!! WTF! is that the reason I can't convert it with TMPGEnc...also, when i try to convert it with LSX MPEG Encoder, it says "illegal frame rate codes, cannot convert frame rate"...what do i do? I got the avi file by converting a rm file with Tinra...just thought youd like to know...HELP!
Easy fix:
Using VirtualDub, choose direct stream copy from audio and video pulldown menu's in VirtualDub, and under video - frame-rate, choose "change so video and audio durations match". Now Choose File - Save AVI.
Hope this helps. more info in the TinraGUI support forum:
http://guiguy.wminds.com/forums/viewtopic.php?topic=25&forum=5&5
<font size=-1>[ This Message was edited by: Clint on 2001-07-18 20:45:42 ]</font>
joining avi files with diff frame rate-error in vd
By leel in forum Newbie / General discussionsReplies: 1Last Post: 18th Dec 2010, 19:49 -
.TRP file Frame Rate conversion
By Jbrend in forum Video ConversionReplies: 3Last Post: 10th Apr 2009, 16:08 -
AutoGK : MPEG2 to Avi Frame Rate Problem
By Mokkori Chan in forum Video ConversionReplies: 6Last Post: 27th Feb 2009, 04:51 -
Avi lowering Frame rate and audio
By vipertongn in forum EditingReplies: 8Last Post: 14th May 2008, 04:31 -
frame rate error apending avi with Virtualdub.
By lilith2014 in forum Newbie / General discussionsReplies: 13Last Post: 19th Aug 2007, 13:52
