I tried to burn a file nearly 2GB or 2GB on DVD as data, but failed.
I am not sure whether there is a limit of file size in DVD or CD? Anybody?
you need to use udf or iso/udf for files bigger than 2gb...or maybe it's 1 gb...not sure..
what burning tool are you using? -
Baldrick - It's definitely 2 GB. Less than that is OK to not use UDF. It would seem that kahooi's file is probably really a little bigger than 2 GB, hence the problem.
ISO format DVD file size limit is 2GB. UDF file size limit is 4GB. Movie DVD file size limit (VOB file) is 1GB.
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 18:29 -
File size differs from data size--HUH?!
By atoledo123 in forum MacReplies: 2Last Post: 9th Sep 2011, 14:19 -
An AVStoDVD non-starter (file-system limitation)
By Seeker47 in forum Video ConversionReplies: 9Last Post: 24th Nov 2010, 11:53 -
Question: MKV File Size vs MP4 File Size
By VideoNoobz in forum MacReplies: 6Last Post: 20th Feb 2010, 03:44 -
Is There A File Size Limitation to Convert .ts?
By toddon14th in forum Newbie / General discussionsReplies: 6Last Post: 17th Jun 2008, 00:04
