What is the Main difference between a DVD Editor and a DVD Author , Like for example DVDREmake Editor V6.0 and TMPGENc DVD Author or DVDLAB Pro or Tsunami MPEQ DVD Author?
Trying to grapple with all the terminologies right now. Thabks
I changed the subject, please use a subject that describes the topic and not just newbie question.
Well.... the names pretty much imply what they do. A editor is for editing a video file. Once you're done editing you export your video file and use authoring software to create your chapters and menus ....
Note that some software can do both. DVD Workshop for example which is primarily for authoring DVD's can also do minor editing but in no way compares to a full blown editor. -
The other distinction is between software designed to create a DVD from stratch (authoring), and software used to alter an existing DVD 9editing). There is some cross-over between some of the software (IFOedit can be used to do both, for instance), but usually a piece software excels at one or the other (or neither)
Read my blog here.
Can ImgBurn burn DVD-9 to DVD-5 and Main Movie only?
By coody in forum DVD RippingReplies: 22Last Post: 1st Jan 2014, 10:14 -
Backup main movie from DVD9 to DVD5 with main & chapter menu's.
By ChibiTomo in forum User guidesReplies: 18Last Post: 18th Jan 2010, 20:27 -
How to full backup (no encoding) BR main movie, main audio with subtitles ?
By meico1234 in forum Blu-ray RippingReplies: 2Last Post: 2nd Feb 2009, 04:37 -
question about difference between TMPGEnc DVD Author and DVD Flick
By jimdagys in forum Authoring (DVD)Replies: 1Last Post: 23rd Apr 2008, 21:06 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
