    May 2006
    Netherlands
    Hi there
    Please can someone tell how to put more than one movie on to a DVD
    thanks 4 your help Tes
  2. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    Are you talking home movies or dvd movies. If your talking dvd movies, Rip the movies with dvddecrypter or dvd fab, use dvdshrink in re-author and add the titles you want from the movies you previously ripped. The quality of the video will get worse the more you put on the dvd.
    Also doing a simple search instead of being lazy would have been the smarter thing to do.....Not a very good first post......just my opinion
    What We Do In Life, Echoes In Eternity....
    May 2006
    Netherlands
    no if U have 2 dvd movies downloaded (DVD Format)how do I put them on one DVD as the vob,bup files are the same on each dvd movie tes
  4. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Just open dvdshrink, in re-author mode. Then choose the folder were the movie is, nad move title over to the left side, the open the 2nd movies folder and drag that title over. Unselect all unwanted audio/extras. then hit back up.
    Apr 2003
    Maryland
    You are really downloading movies in DVD format?? Legal stuff I hope. If yes then I would say to you to try NOT to cram two full length movies onto one DVD 5 maybe a DVD DL as you will most certainly loose quality. DVD blanks are dirt cheap. For goodness sakes, just burn each o to its own disk. Less work and the quality will at least be equal to what you downloaded.
    And remember that if it is not public domain ( free ) or legal paid for downloads you cannot discuss that here. It would be warez.
    No DVD can withstand the power of DVDShrink along with AnyDVD!
