Hi all,
Final 2.1.1 Release is on line.
https://www.videohelp.com/~jsoto/vobblanker.htm
http://jsoto.posunplugged.com/vobblanker.htm
changelog (from 2.1.0)
- Added: Multiple Cut. Cutting at cell level is now supported, so up to one cut per cell can be done per process session.
- Added: Cut cells capability in MENU domain.
- Added: Added some shortcuts in Main dialog Menu
- Menu Still all PGCs with audio
- Menu Still all PGCs w/o audio
- Menu Delete all no buttons PGCs- Added: Re-run is now allowed without reload the project if "Use input folder" was not checked
- Added: Error checking in writting process (if disk full, i.e.). Also added a check on the available/required disk space before start processing.
- Added: I'm done audio alarm using two wav files: DoneOK.wav and DoneKO.wav.
- Improvement: Detection of ILV-ed Cells in KEEP mode with automatic activation of Fix VOB internal pointers phase. Very useful when stripping angles.
- Improvement: Detection of angles reading the PGCs in the IFO, instead of trust VIDEO_TS.IFO Titles table. Number of angles modified to one in all PGCs of a processed VTSs.
- Changed: Blank auto now keeps the PGCs with duration longer than 85% of the longest one. Useful for episodic DVDs
- Changed: Using last version of DVDPreview
- Changed: Disabled loading a PGC in Tiny in the case of multiple selection
- Changed: Statically linked mfc42. Seems wine did not work with shared dll
- Changed: Default of Autostart Tiny changed to False.
- BugFix: TMAPTI Overwrites next sector in some cases of wrong input IFOs
- BugFix: Loading "Process Titles" setting from project file was broken in 2.1.0.
- BugFix: Setting to default values in main dialog were the old ones (not updated)
- BugFix: Combinations of Reusing Language Units and deleting/blanking the reused LUs did not work well
- BugFix: Copying Audio Attributes when replacing did not work in some cases
- BugFix: Abort button in cells dialog did not move when resizing
- BugFix: All PGCs were always shown as non-ILVed.
- BugFix: Decoding the subs (to get their duration) failed in some cases, and an additional bug decoding wrong sub commands caused VobBlanker to hang in an infinite loop
- BugFix: Audio and subs attributes were not updated in VMG_VTS_ATRT of VIDEO_TS.IFO when copying the attributes from a replacing PGC. Now, VobBlanker always copies all the attributes (audio/video/subs) from the processed VTSs in menus and titles domain to this table of VMGR.
- BugFix: Copying audio/subs attributes when replacing a PGC did not copy all of the attributes
jsoto
Results 1 to 1 of 1
VobBlanker substituir o menu/How to replace DVD menus with VobBlanker
By escarlate in forum Authoring (DVD)Replies: 24Last Post: 31st May 2011, 02:52 -
VobBlanker
By jjis in forum DVD RippingReplies: 2Last Post: 5th May 2010, 19:03 -
Problem with Vobblanker
By m-man in forum EditingReplies: 8Last Post: 29th Jan 2008, 17:58 -
VobBlanker vs. DVDShrink
By hech54 in forum DVD RippingReplies: 10Last Post: 19th Oct 2007, 02:39 -
VobBlanker 2.1.3 released
By jsoto in forum Latest Video NewsReplies: 12Last Post: 26th Jul 2007, 19:22
